6 Solo Seat Cover Needed
Last Post: jortegaa3289
Posted On: 12-01-2021
Posted On: 11-29-2021
21" Doom Front wheel needed
Last Post: LorenzoHD
Posted On: 11-26-2021
Evil Bitch
Last Post: Choppa
Old 11-20-2011, 08:16 PM
kxmotox247's Avatar
Redneck Lowlife Build - 0up 5out 42 deg
Pictures of my build. Redneck lowlife 0 up, 5 out. This was an abandoned project at a fairly reputable shop that I picked up a few years ago. Craftsmanship on their part was terrible. Tank mounts were crooked. Fender wasn't straight. I'm still uncovering mysteries of why they did stuff the way they did. This was supposed to be a 40 deg frame but is actually a 42.
I'm building this one on a budget. Smaller Evo motor and 5 speed. Simple. Going to be either black or silver. Tonight was the first night that I was able to roll it off the lift. Last few things to do before paint is mount licenseand add extra gusset to neck. A few other small things as well. Since this is my first build from the beginning, I'm cautious that I dont overlook something prior to break down for paint. Goal is to get the mock up completely done before it's so cold that I can see my breath in the shop. Hope you guys like it.
Redneck Lowlife Build - 0up 5out 42 deg-11-20-2011_-38-resize.jpg   Redneck Lowlife Build - 0up 5out 42 deg-11-20-2011_-33-resize.jpg   Redneck Lowlife Build - 0up 5out 42 deg-11-20-2011_-34-resize.jpg   Redneck Lowlife Build - 0up 5out 42 deg-11-20-2011_-35-resize.jpg   Redneck Lowlife Build - 0up 5out 42 deg-11-20-2011_-36-resize.jpg
Old 11-20-2011, 08:34 PM
looks cool... so does the street rod...
Old 11-20-2011, 08:56 PM
beebster's Avatar
Yup it gonna b cool! looks like ya got some 67-72 gm trucks there two,post up sum pics of them too!!!
When ya git back to town, could ya tell em.....
To send back a truck!.
Old 11-21-2011, 09:24 AM
kxmotox247's Avatar
Thanks guys. Street rods are my passion but bikes are a good change of pace. Would post some pics of the trucks but someone may get upset saying it's too off topic.
I appreciate the help that's on this message board. I pretty much read all the new topics on Shop Talk on a daily basis. People have been extremely helpful when I've asked questions. I'm sure I'll have more as I go along. I've got almost everything to finish the build as far as parts. Just some small stuff like oil lines, brake lines, fittings. I've bought lots of stuff used which helps the budget. I'm a little nervous about wiring but this bike should be simple. I guess I'll use one of the wiring diagrams in the tech section and modify it a little. Just don't want to discover that I should have drilled a hole to pull a wire after everything is painted.
Old 11-21-2011, 10:01 AM
I think this may be the best for simplicity;
http://www.ultimaproducts.com/18-536.pdf
Also, this is about as bare bones as it comes;
My Photo Gallery - wiring_diagram31
Old 11-21-2011, 11:17 AM
kxmotox247's Avatar
The diagram is about perfect. I need to add a horn and in IL we have to put in a brake switch for the front brakes
What do people do about the headlight ground? There's a hole in my neck presumably for running headlight wires but no way you can get three thru that hole. Are they just grounding through the headlight and then the neck bearings....? Putting a hi/lo switch on the headlight in an inconspicuous spot would be like tities and beer. Simple.
Not sure if I have room for the Ultima module under the backbone. I think so. Need a small horn too.
Old 11-21-2011, 11:22 AM
kxmotox247's Avatar
Just looked at the Jireh website for a pic of the module. No sizes listed but it looks no bigger than a regular relay. I suppose I would need to keep that in an easy to get to spot for servicing the elctrical like under the seat.
Old 11-21-2011, 11:42 AM
The 18-536 is approximately the size of a Bosch type relay. Wherever you can put a relay, you can put the 18-536.
All your wires for the headlight can be run through the hole in the neck and into the backbone. It's never too small, there's a reason bigger drill bits are made.
As far as the brakelight switch, I think I would mount it under the trans.
If you wire from scratch you may find this diagram more complete.
My Photo Gallery - WiringDiagramHD1
By the way, have you been working on this since '04?
Old 11-21-2011, 12:34 PM
kxmotox247's Avatar
Thanks. Maybe the module would be handy. I'll have to size things up again under the seat.
In IL we have to have 2 brake light switches. One for front brake and one for the rear. I bought one to go on the front master cylinder banjo. So more wires there. Just not keen on opening the hole up and having 3 wires for the headlight, and 2-3 more wires for the brake light and horn.
The 04 is the one that I had Redneck assemble. I did the paint work and had the frame chromed and they assembled it and titled it.
I bought this frame in 08'. I've been accumulating parts slowly since then but only began to assemble it recently. In March/April I began to assemble it assuming that the shop I got it from had some things right. WRONG. They solid welded in the rear fender which may work for some but it doesn't for me. Way too hard to paint like that. It was crooked. I could only get 3 out of 4 bolts in the tank...mounts were wrong. For some stupid reason they cut off the tabs for the internal fork stops off the neck. Just a host of problems. But a grinder, welder and access to a machine shop has taken care of most of them.
Old 11-22-2011, 06:37 PM
kxmotox247's Avatar
Tailight mounted. Need to cut the gusset at work still. This is an early frame... 2002/2003 and doesn't have any neck gusset at all. They added one... makes me think I should add one.
Old 02-11-2012, 09:03 PM
kxmotox247's Avatar
Just before teardown around Thanksgiving. Had some welding to do once disassembled.
Second picture is the frame back from Powdercoater. Bike black is the color. A really nice glossy black. Very happy with it. I spent a lot of time adding and blending welds on the frame. They came out great. Had the bars done too. Spent every minute I had over x-mas vacation and the holidays painting the tank, fenders and oil tank. All house of kolor black. Nothing fancy. But you can't beat glossy black paint for simplicity and class. I want this bike to stay simple. A little concerned that there's too much black though. Have the lowers for sale in the classifieds and would like to get some chrome up there.
It's cold here. 35 degrees in the shop but I was ready to finally set the engine in place. I don't enjoy frozen fingers but I'm excited. Oil tank is bolted in. Kind of a downfall with the Redneck frames that you cant take it in and out without pulling the motor. Anyway... it's in. Engine is setting in place. Gotta get some longer bolts. Getting the trans ready to drop in. Have to shave down 4 of the studs. Inner primary needs some new seals and then i'll put it on. Still gotta figure out what locking tab is used for this PBI sprocket (never had a chain final drive).
I'll update more as I move forward. I'm really anxious to keep moving.
Redneck Lowlife Build - 0up 5out 42 deg-redneckbpc.jpg   Redneck Lowlife Build - 0up 5out 42 deg-redneckpc.jpg   Redneck Lowlife Build - 0up 5out 42 deg-redneckpc1.jpg   Redneck Lowlife Build - 0up 5out 42 deg-redneckpc2.jpg
Old 02-11-2012, 09:18 PM
thats a cool bike..
Old 03-18-2012, 10:35 PM
kxmotox247's Avatar
Almost finished... just add fuel!
Redneck Lowlife Build - 0up 5out 42 deg-redneck-3-17-12f.jpg   Redneck Lowlife Build - 0up 5out 42 deg-redneck-3-17-12g.jpg   Redneck Lowlife Build - 0up 5out 42 deg-redneck-3-17-12c.jpg   Redneck Lowlife Build - 0up 5out 42 deg-redneck-3-17-12e.jpg
Old 03-19-2012, 10:37 AM
matt'sdrag95's Avatar
looks nice and clean. Nice job bud.
Old 03-23-2012, 07:33 PM
kxmotox247's Avatar
Thanks.
Fighting a few battles right now. Bike fired on the first push of the button. It pulls pretty hard. Taking it easy as I break it in.
