Last Post: bjh
Worth Chopping?
Ultima 113
Posted On: 06-04-2020
Last Post: Southpaw1746
Posted On: 06-03-2020
Old 07-20-2011, 04:31 PM
Donovan's Avatar
How to adjsut kv's?
I never have had a gun that adjust kv's. But i ordered one today. Just wonder how do i know to increase the kv's or to decrease them thanks.
Donovan
Old 07-21-2011, 05:06 AM
Streetwerkz's Avatar
Bike Year, Make, Engine: 06 Yamaha Roadliner
What is your kv range on the gun you ordered?
Most parts can be shot at 70-90 kv's with no problem
second coats require the kv setting to be reduced to 40-60 kv's with our Nordson powder gun
I like to shoot metallics at 50-60 kv's so the metallic pigments don't get to excited from the charge & lay flat on the part.
This basic info should get you going, the rest you will learn from new gained experience, trail and error & practice, practice, practice
Good luck!!!
www.STREETWERKZ.com
Custom Powder Coating & Media Blasting
http://www.facebook.com/#/profile.ph...00000211105322
Old 07-21-2011, 02:40 PM
Donovan's Avatar
I have a range of 30-50 (spectracoat es-hobby) and i'm doing motorcycle sheilds. Mostly 20% black powder, and that's it. How would i choose where to set it at?
Donovan
Old 07-22-2011, 04:48 AM
50 kv's will be fine for most colors solid or metallics
www.STREETWERKZ.com
Old 09-10-2012, 05:33 PM
The real question I have isnt the KV adjustment which KV adjustment is over rated but Micro Amp adjustments which is where the Magic happens. Being a Nordson Distributor and Certified Nordson Trainer I can tell you that Micro Amp adjustment is a incredible feature with all powder especially with Incapsulated metallics or Non Incapsulated metallics.
Old 04-17-2020, 10:32 AM
you must bought a manual gun, there should be a adjusting knob to control the voltage .
