Top mount hardware
Last Post: muddychops
Show us your bike!!
Posted On: 12-05-2022
Got Tanks
help needed
Last Post: johnevo
Posted On: 12-03-2022
Posted On: 11-21-2022
  #106 (permalink)
Old 03-17-2022, 05:00 PM
Hammer crimping:
Small 1 1/4" pipe rounded off roughly is ok clamped in the vice:
Hammer , hammer , hammer around the edge rounding it over:
And like that ,a bit at a time nd watch the tube end curl in:
And a nice clean muffler shape:
  #107 (permalink)
Old 03-22-2022, 12:07 AM
Pipes at 50% done after an extensive session:
Buncha tooling made for the work too if any one gives a fuck.
  #108 (permalink)
Old 03-24-2022, 09:18 AM
Mounts start with the welding of a 3/8" bolt into a washer, these will be welded to the pipes themselves:
  #109 (permalink)
  #110 (permalink)
Old 03-24-2022, 12:22 PM
Pipes completed with proper brackets:
  #111 (permalink)
Old 03-25-2022, 09:01 AM
A nice set of pipes unique to this bike , straight , and mounted properly . This is the essence of chopper building , properly made and mounted parts.
  #112 (permalink)
Old 03-27-2022, 12:33 PM
Took a break from steel fab to CNC a matching wood panel for the top motor mount cover and the long awauted coil box cover:
  #113 (permalink)
Old 03-28-2022, 04:53 AM
Nice work
Well, when all the right skills and tools are combined...
Looks pro, not garage build...
  #114 (permalink)
Old 04-03-2022, 10:33 AM
Thanks.
Just checking the look of the pipes;
And the 7 degreee 'splay' the pipes take off the frame line.
Now I can pull them off and get the ends painted and then wrap them , they'll get put away as I stiff hafta get this bike out of my house and they are adding to the width!
  #115 (permalink)
Old 05-01-2022, 01:50 PM
Had to leave this for a while .
Coming back slowly with the sorting of the oil pressure gauge and switch.
I was gonna have the switch off the rear of the engine but the lines look good and I dont want to mess with them.
At the front of the engine there is a handy port to the oil system.
So I re-purposed a brass fitting , it has 3 off 1/8 NPT threaded holes , 1 for the feed , 1 for the gauge and one for the switch:
I dont have the switch yet.
Thanks for lookin' and not commenting.
  #116 (permalink)
Old 05-14-2022, 04:24 PM
Oil pressure sending switch installed:
  #117 (permalink)
Old 05-17-2022, 10:47 AM
A little carb checking today:
  #118 (permalink)
Old 05-26-2022, 07:40 PM
S&S kit showed up:
Excellent fit and product as is the usual from that company.
As in previous posts there is the opportunity to utilize some more of the cool burlwood. I soon found there was not enough for a 1 piece air cleaner cover. Some quick computer work and I was able to produce adhesive mask material cut into pie shapes.
You can guess where this is going:
  #119 (permalink)
Old 05-30-2022, 10:23 AM
Point cover and cam sensor block off plate work:
Checking block off plate fit:
  #120 (permalink)
Old 05-31-2022, 10:39 PM
Parts came in so more work can commence:
MAP sensor and stepped on cats eye tailight.
