Last Post: Oldsmobile5798
Fender grommets
Last Post: muddychops
Trikes first run
Posted On: 10-23-2021
Old 09-22-2014, 05:31 PM
Trying to ID this build.
Hey Guys,
Looking for a little help from the pros on identifying Frame/Forks/Engine/Trans or anything else, if you know what it is.
Want to try and replicate this chopper but need some schooling on what is what.
I have a link to hi-resolution photos which you can download to zoom in on if you like. Let me know.
Any insight would be greatly appreciated.
Thank you
Old 09-28-2014, 01:03 PM
I am not an expert but I can help.
The engine is a shovel head engine.
Cast Iron cylinders.
It has a kick 4 speed trans unless internally altered. (doubtful)
Flat style trailer fender.
King and Queen seat with sissy bar.
Springer front forks.
21" front wheel. 2.15 width. Avon style tire.
Rigid style frame. Looks stock.
"Z" handlebars.
Looks like a 16 inch rear wheel.
Best I can do.
Old 09-29-2014, 04:49 AM
Rockhewer's Avatar
Got Rock?
Bike Year, Make, Engine: '06 garage-built (FTF) S&S
suicide shift with an old stick for a shift lever, and highway pegs... Possibly driftwood for more "character"
And don't forget the high tech paracord mounting system....possibly some gaffer's tape involved here & there.
<img src=http://www.clubchopper.com/forums/image.php?type=sigpic&userid=11872&dateline=1255376211 border=0 alt= />
Support- Bikers Against Child Abuse... No child deserves to live in fear.
Old 09-29-2014, 07:43 AM
generator shovel, not cone shovel.
Old 09-29-2014, 08:02 AM
Looks like a paughco wishbone frame, with a 45 degree rake seemingly.
Springer seems like 6-8 over.
Old 09-29-2014, 08:08 AM
I hope you're not going to try to fake the dirt and rust too.
Old 09-29-2014, 10:18 AM
Bike Year, Make, Engine: 2006 Custom
I agree with most others. Looks to be a repop cradle frame since it looks like it never had sidecar hoops. No up, or out stretch. I personally think the rake is more like 37 degrees with a 6 or 8 over springer.
Old 10-15-2014, 05:04 PM
caschnd1's Avatar
That's definitely an original Panhead rigid frame. You can tell by the rear axle plates and the top motor mount. The sidecar loops have been hacked off. That's also a panhead bottom end w/ shovel heads installed. It was a common modification in the 60's and 70's.
-Craig
Old 10-15-2014, 08:49 PM
BadDawg's Avatar
Bike Year, Make, Engine: 2004 Bad Dog chopper
-Craig
If it is a panhead frame then it was raked because that springer is over and the bike is level.
Old 10-15-2014, 09:00 PM
caschnd1's Avatar
Yes. It's definately been raked. I'd guess 5/8" of rake which works out to about 37 or 38 degrees.
Old 04-26-2015, 07:43 PM
Bike Year, Make, Engine: Sportster 1980 Harley Davidson
It has one trick that shoudn't get skipped. That sissy bar keeps the chick you pack from bouncing off when the regid frame hits some bump that causes her to bounce.
E equals MC squared
