Last Post: Oldsmobile5798
Fender grommets
Last Post: muddychops
Trikes first run
Posted On: 10-23-2021
Old 05-08-2020, 08:49 AM
wide tire setups on shaft drive builds
Now I know most of the bikes floating around with this kind of modification have much LARGE tires on the bike...but I'm looking at put a 170 or 180 on the back of a Honda CX500 (you can see the build here. Right now I'm picturing it by having a custom CV shaft made to let me move the dif over about 30mm.
I'm wondering if there are other ways and I just feel like this is a territory some of you might be more versed in.
I'm also quite interested in stock steel shaft drive swingarms with offset final drives that might accommodate a 180mm tire...if any exist.
Your feedback would be appreciated!
Old 07-13-2021, 10:44 AM
I know this post is a year old, but VTXs do have a wide tire kit you can get. I'm wanting to use one on my proejct, but the angle the shaft has to take is sharp. I might stretch the rear a bit to give the shaft a shallower angle.
