Looking for Talon lowers
Last Post: John Spartan
Posted On: 01-15-2018
Last Post: SKT
WCC coffin air cleaner
Posted On: 01-13-2018
Old 06-09-2008, 06:04 AM
Bike Year, Make, Engine: custom
anyone have plans for tubing roller
i have seen plans for lots of diffrent tubing benders, anyone have a set of plans for tubing roller? i would love to build me one. or if someone may know where on the net to find.
www.wickedwillychoppers.com
wicked willy
Old 06-09-2008, 06:05 AM
i guess correct name is roll bender for tubbing
wicked willy
Old 06-09-2008, 04:01 PM
paulhusd's Avatar
I have drawings of how I built my roll bender but they are drawn in CAD I might have saved them as an excel file though I will check tonight as I am at work now..
Darryl Paulhus
Goulburn NSW Australia
Old 06-09-2008, 04:03 PM
paulhusd's Avatar
Can take a picture of the one I built also, for a look at how I built mine to get you started..
Darryl Paulhus
Old 06-10-2008, 01:22 PM
MechWerks's Avatar
Here is a picture of one I built. Used the machine to roll pipe into the handle. A round wheel handle is much easier to work than other handles.
What size tube do you expect to roll? You will be surprised how much effort it can take to roll tube. The industrial term is "angle roll" for the machine used to radius bend metal and does tube and pipe with proper dies. The dies will be the tough part. Wood and plastic can be used with the right machine design. Otherwise a lathe and radius attachement (another home made tool) will make dies...or expect about $100 each for purchased dies. www.pro-tools.com was the inspiration for my bender. A hunt around the web will toss up dozens of examples.
MechWerks
Old 06-10-2008, 02:32 PM
Bike Year, Make, Engine: In Progress
Damn hippies got plans for anything....
http://www.motherearthnews.com/Green...ng-Roller.aspx
On the downside, the illustrations (you have to click on the "images" links") aren't much help...but on the upside you can also find plans to build a kite from recycled materials.
Old 06-10-2008, 03:26 PM
Bike Year, Make, Engine: 2005 Fat Bastard 200
Here is a picture of one that we have on Metalmeet. www.metalmeet.com/forum/showthread.php?t=11083
Old 07-11-2008, 04:18 PM
paulhusd's Avatar
Pictures of the ring roller I made I mount a 20 ton air powered bottle jack in the top to push down on the top roller. I tried a 8 ton jack but it would not even budge 2" tubing when I was making the backbone for my frame. I use a 1/2" ratchet with a 3 ft long bar welded on to turn the bottom rollers, chain and sprockets I bought at a farm supply store. I used 1" 4130 bar for the shafts. The sideplates I had waterjet cut from 12mm thick aluminum plate as I was getting some other things cut at the same time.
Name:  Roll Bender1.JPG
Name:  Roll Bender2.JPG
Name:  Roll Bender3.JPG
Darryl Paulhus
Old 07-11-2008, 04:19 PM
paulhusd's Avatar
Shit sorry I should have turned the pictures around..
Darryl Paulhus
Old 07-11-2008, 04:25 PM
paulhusd's Avatar
Drawing of the side plates for the ring roller I built. The center slot that the top roller runs up and down in does need to be extended down at least another 3 inches I learned that after getting together and it would not go low enough when I was rolling my frame backbone.
Roll Bender Side Plates Model (1).pdf
Darryl Paulhus
Old 07-12-2008, 05:18 AM
thanks,
wicked willy
Old 07-17-2008, 09:59 PM
Bike Year, Make, Engine: 2005 boulevard s-83, 95 honda cbr900rr
Attachment 25938
Attachment 25939
Attachment 25940
Where did you get the rollers from? Did you have them made or did you buy them somewhere? Also, what do you do when you move the bottom two rollers to the other holes? Do you have extra links for the chain or what???
Old 07-28-2008, 09:34 PM
sumojo's Avatar
Bike Year, Make, Engine: No bike yet and that sucks
Send a message via AIM to sumojo
ouch my neck LOL hey that in a nice one
