I'm Baaaaaaaack...
Last Post: axeychrome
Posted On: 10-23-2020
Teardrop Gas Tank Replacement
Last Post: R1_4Life
Posted On: 10-22-2020
Posted On: 10-21-2020
Old 06-14-2017, 05:45 AM
Bending Hell Bent pipes
I have a set of Hell Bent pipes and the one by the oil bag is too close. Is it possible to heat this pipe and bend it a little bit? Or will I ruin the pipe? I am going to have them powder coated black so don't care about the finish...
Old 06-14-2017, 04:51 PM
Yes , you can do it...but the mistake that a lot of people make is not heating enough area so they end up with a kink..there is a procedure where they pack sand in the area to be bent to prevent the kink..I saw a you tube video on it..you may not need that to bend a little though...Be sure to heat on each side of the stress point..
Old 06-15-2017, 05:11 AM
Thanks for you information!
Old 06-25-2017, 12:45 PM
If you fill with sand make sure it is dry dry dry no moisture
