Go Back   Club Chopper Forums > CUSTOM BUILDERS/DISTRIBUTORS > JB Customs
Door replacement
Last Post: kortny_or
Posted On: 12-04-2021
Last Post: ZIKY
Congrats to Mitch Bergeron
Last Post: jortegaa3289
Posted On: 12-03-2021
Old 04-13-2008, 05:50 PM
occparts's Avatar
Bike Year, Make, Engine: Which one?
Thumbs up bike build
I recently was able to pick up a frame that was made by Racing Innovations. This is 1 of only 2 frames like it in the world. The other frame was used bu OCC to make a bike for Snap On. I will be posting pics of this build as I have time to work on it. I have collected most of the parts for the build. I will be using an Evo motor that bought that blown up. I will be assembling the motor,but I have to have someone else do the machine work as I don't have the equipment to do it with.
JB Customs
2422 W. Michigan Ave
Jackson,Michigan 49202
517-787-8730
jbcustoms.com
Motorcycles are one of life's many pleasures!
Old 04-13-2008, 06:00 PM
apehangeralfy's Avatar
Looking forward to it, keep us posted!!!!
Old 04-13-2008, 06:39 PM
Promise us you won't be using "buying parts" and "OCC" in the same sentance again.
"We cheat the other guy and pass the savings on to you."
Old 04-13-2008, 07:56 PM
occparts's Avatar
ok,ok,I will tell you that some of the parts came from OCC. Parts that they got and didn't use. Like the frame,transmission,hand controls. Otherwise I have been getting parts from here and there just like 75%of the guys on here who have built a bike. I will have $6-8k plus the frame,in this bike when I am done,maybe less. It won't be a hot rod with 130 at the rear wheel,but it should be dependable and look good. As time goes on,I will upgrade as I can.
JB Customs
517-787-8730
jbcustoms.com
Old 04-14-2008, 08:59 PM
occparts's Avatar
JB Customs
517-787-8730
jbcustoms.com
Old 04-14-2008, 09:24 PM
Rockhewer's Avatar
Got Rock?
Bike Year, Make, Engine: '06 garage-built (FTF) S&S
Hey, that looks bad to the bone man!
so those tubes are what, hexagonal?
how do they make that .......I mean like regular tube is "DOM" (drawn over mandrel?)........iis that done the same.....or....what?..
Is it supposed to be as strong or less as round?
(sorry, no metalurgist here)
<img src=http://www.clubchopper.com/forums/image.php?type=sigpic&userid=11872&dateline=1255376211 border=0 alt= />
Support- Bikers Against Child Abuse... No child deserves to live in fear.
Old 04-14-2008, 09:35 PM
occparts's Avatar
It was made from solid bar stock-heavy,but very strong
JB Customs
517-787-8730
jbcustoms.com
Old 04-14-2008, 09:36 PM
Razorback's Avatar
Cool ....looks like your off to a good start. Keep us updated with progress.
Old 04-14-2008, 09:49 PM
occparts's Avatar
It is an 8 up,5 out,40 degrees of rake. Will be putting a 16 over front end on it with 5 more degrees in the trees. The fram is made from hexagon bar stock. It was bored out in the back bone and the down tube under seat for internal wiring. I am using Accutronix triple tree and forward control. The lower legs are Mean Street. The trans and motor have 1 1/4 in offset. The motor is an Evo that I traded for that was blown up. I have to replace the rods,cylinders and pistons. I having the new cylinders bored out to 20 over and I am putting Keith Black pistons in it. Let's see, a 240 rear with wire wheels,Metzler tires,Mikuni HSR 42 carb with Vance and Hines exhaust. The hand controls are Joker Machine JX controls with hyd clutch. Enclosed primary for now,might change it out later,oh and a West Coast Choppers rear fender.
JB Customs
517-787-8730
jbcustoms.com
Old 04-14-2008, 09:53 PM
occparts's Avatar
Thanks Rockhewer and Razorback,I hope to have it completed with in a couple of months so that I can get it out on the road.
It may not turn out like this
but it will be something I have done with my own hands.
JB Customs
517-787-8730
jbcustoms.com
Old 04-14-2008, 10:08 PM
Phantom's Avatar
It seems that vibration will be an issue. Rubber mount everything you can to help isolate as much as possible.
www.PhantomChoppers.com
Old 04-14-2008, 10:25 PM
occparts's Avatar
Hadn't thought about that-you might be right on that. The harmonics might travel through the frame. What do you think? A thin layer of rubber under motor mounts? or regular rubber mounts under motor? That was a good point. I was thinking that there is no way that this frame will have any twist in it. Never gave a thought to the harmonic of the vibrations traveling through it.
JB Customs
517-787-8730
jbcustoms.com
Old 04-15-2008, 05:46 AM
I think, but I could be wrong, that Jay was refering to oil bag, battery tray, shit like that. You do not want to rubber mount your drive train. Again, could be wrong but don't think I am. Looks pretty cool though!!!
Old 04-15-2008, 06:49 AM
occparts's Avatar
Well,oil bag/battery tray is rubber mounted or will be. Maybe I am overthinking what he was saying.
JB Customs
517-787-8730
jbcustoms.com
Old 04-15-2008, 01:03 PM
Phantom's Avatar
You don't want to put rubber under your engine unless you want to go with a traditional rubber mount set-up which is designed for that. Put your seat up on springs, use rubber dampeners for your handlebar mounts and maybe even a bar snake in your bars. Basically, anything you can do to isolate you from the vibration will probably do a world of good I would think.
