6 Solo Seat Cover Needed
Last Post: jortegaa3289
Posted On: 11-29-2021
21" Doom Front wheel needed
Last Post: LorenzoHD
Posted On: 11-26-2021
Evil Bitch
Last Post: Choppa
Brembo brake ID
Posted On: 11-24-2021
Old 01-17-2014, 06:43 AM
Bike Year, Make, Engine: 07 A.I.H. Tejas, 111 SanS Super Sidewind
Tejas open primary conversion help
Hello all, I ride a 2007 AIH Tejas, right side drive with a 111 S an S power plant. My question is, I would like to convert it to a 3 inch open primary drive. I have tried emailing some of the different makers of such and not one response from any of them. So is there anyone out there that could help me sort out this problem. I don't know what to order because I don't know what will fit it. If you need more info for your input please ask. Also i'm running a 280 rear tire if that helps. Thanks for taking the time to read this. God Bless........................
Old 01-17-2014, 04:26 PM
barl's Avatar
Bike Year, Make, Engine: 05 custom 127"
Seems to me the s&s 111 is based on the evo design and depending on what trans your running most any open primary designed for your motor and trans setup should work...most all aftermarket frames for the evo use the same measurements for engine and transmission placement..anyone else know
If it ain't broke don't fix it.
Old 01-17-2014, 07:25 PM
I can help......PM me I will tell you what fits and try to give you the best deal on one that best suits your taste........
Old 01-17-2014, 07:33 PM
The tranny is a Roadmax 6 speed and the frame is by Daytec
Old 01-17-2014, 07:35 PM
Will give you a P. M. on that . Thanks
Old 01-17-2014, 07:37 PM
90-99 Softail should be the fitment you need.......
