Last Post: Crowy
Last Post: manser
Last Post: 250CFL
Old 06-26-2010, 08:35 PM
Bike Year, Make, Engine: 113" Walzesque, 96" DAYTEC hybrid
Originally Posted by RedWings View Post
I would like to try some of that stuff whats it called anyways.
HERE'S THE PLACE, THEY HAVE EXPLANATIONS. 2 BAGS OF BEADS + S&H WILL COST AROUND 15-20 BUCKS. INSTALLED RIGHT THROUGHT THE VALVE . YOU DON'T LIKE IT- JUST CRACK THE TIRE OPEN AND POUR THEM OUT.
http://www.innovativebalancing.com/gallery1.htm
REMEMBER, I THINK, 'BALANCE MASTERS'?- MERCURY DROPLET RUNNING FREELY IN A ROUND SOLDERED TUBE ATTACHED TO THE GROOVE IN THE CRANKSHAFT ? THE SAME PRINCIPLE.
Old 06-26-2010, 08:39 PM
nanaimoBC's Avatar
Bike Year, Make, Engine: 2007 nemesis 250R
ya the 250 sucked on mine also couldn't get the bead to pop figure wasn't enough air ...ended up at the 18 wheeler shop and they spent almost an hr finally got it with the big air tank they jam past the bead and crack the valve ... same one they use for their truck tires...they were amassed it was such a bitch to get
Old 06-26-2010, 08:44 PM
I've never heard of that but it won't work with mine. I put tubes in them
Old 06-26-2010, 08:49 PM
I think you can...
Originally Posted by spartacus View Post
i've never heard of that but it won't work with mine. I put tubes in them
i believe the site says they can be used for tubed tires- you still pour them through the valve( with the core removed).
Old 06-26-2010, 09:12 PM
Just looked at the site. It does say that they can be used in tubes. Might be worth looking into. Those weights are ugly
Old 06-26-2010, 09:13 PM
has anyone on here used them?
Old 06-26-2010, 09:21 PM
I would like to try it cause I've never had a balanced rim cause of those yougly fuckin weights. I run tubes to and they can throw the balance WAY out.
Old 06-27-2010, 06:43 AM
I have
as you can see - my front is spoked- i presume tubed( sorry the wheel came with tire mounted and dyna beads[1oz] already in-the guy was swearing by the setup)
the rear solid wheel i mounted in a local shop, tubeless 200 tire. In a few days i received 2 oz bag of beads($7) and poured them into the valve. Put the core back, pumped the tire and done.
Let's say i don't know how would it be with weights, but i don't feel any vibration at either low or high speed.
I think some other used it before with a success.
Old 06-27-2010, 02:47 PM
I use them too - Jake does them at lowdownchopshop - dyna beads
Old 06-27-2010, 03:49 PM
Uklee,,,,any feedbck on them?
Old 06-28-2010, 06:03 AM
Vnygra's Avatar
Bike Year, Make, Engine: 05' buell chop
sounds like my bike. nemesis 250 , black , stripes
Always remember you're unique. Just like everyone else.
Experience is something you don't get until just after you need it.
Old 06-28-2010, 03:44 PM
Nice scoot, and I like the bar setup in the garage.....nice
Old 06-30-2010, 06:54 AM
got my bars from Biltwell yesterday. Nice stuff...$109. Saw another member on here with them and liked them so I purchased a set.
Old 07-03-2010, 03:50 AM
Bike Year, Make, Engine: Ground up Custom
Send a message via AIM to warpedsv
those look awesome
Old 07-03-2010, 11:38 AM
My bike seems to run well with them as does the HD. You might as well try them - they're something like $3 a bag. Nothing to lose. Well, $3 I suppose...
This is where I get mine. http://lowdownchopshop.com/
The owner, Jake, is a member on the Big Dog forum - a good man.
