Club Chopper Forums
-   Hardcore II/Outlaw Builds (http://www.clubchopper.com/forums/hardcore-ii-outlaw-builds/)
-   -   Hard Core II builders (http://www.clubchopper.com/forums/hardcore-ii-outlaw-builds/5233-hard-core-ii-builders.html)
Punisher 04-06-2004 02:28 PM
To all the Hard Core II builders.
I have one for ya. This stupid rear fender strap. What bolts did you use to mount that to the frame,,, and how did you attach it to the rear fender??
I was going to bolt it to the frame, and weld it to the fender, but getting the placement of it is a bit tricky. I do have the other three fender mounts drilled, and tightened. But this strap has me thinkingÖ.
How did you guys attach the strap to the fender? And yes pictures are worth a thousand words.
Punisher
mikemc 04-06-2004 04:10 PM
Punisher,
I welded my support bracket to the fender. It took a little tweaking of the support bracket because of the fender not being true. Also the bolts that came with my kit for securing the fender support, they didnít fit. I had to get new ones I think the threads were different. Sorry I donít have any PICS my tins are still with the painter.
Mike
Punisher 04-06-2004 05:00 PM
That is the very same thing I ran into.
Thanks for the info!
Punisher
SapperLohr 04-06-2004 05:12 PM
Re: Hard Core II builders
Punisher
I had to buy new bolts as well. I am using a double-sided tape used in horse-trailer construction to attach the fender to the hanger, in case the next owner ever has to remove the fender. It is expensive, but lasts forever.
Punisher 04-06-2004 05:58 PM
Hey Sgt, nice to see your still around, hows the trainees???
Thanks for the input on this silly strap. Sure would be nice to have a strutless support back there. but I'll live with it.
Did anyone paint theirs?? I was gonna have mine painted.
I finally got mine from the shop today, and will be taking the after pics tomorrow so I can post them.
We need to start a thread for the builders of the HCII so we can keep tabs on the progress of each others builds.
Anyway, thanks again for the input,
Punisher
mikemc 04-06-2004 06:02 PM
I had my fender strut painted to match the base color of my bike. I'm hoping to have my tins back this week.
Punisher 04-06-2004 06:49 PM
After taking a look at Chopper Wop pics, I do have another question for ya guys.
I have mocked up the bike and since taken off the rear wheel and each time I managed to scrape it against the frame marring up the pulley because the brake bracket didnít come off with the tire.
Now on my HD, this is not necessary, as the wheel can be removed with out it. Is this not the case here with the HCII?
How can I protect the soon to be painted frame, and the pulley and or brake bracket from further abuse?????
As always, thanks for the help.
Punisher
BigRock4545 04-06-2004 06:50 PM
Punisher,
I think a thread for the Hardcore II is a great idea. We should do it to it.
Rock
SapperLohr 04-06-2004 07:06 PM
Punisher
There is a thread.....can't remember what it is called, I think it is just "Hard Core II"
Trainees are a little tired........but they will live. Don't work too hard-later
Chopper Pirate 04-07-2004 04:09 AM
SapperLohr
Where do I get that special double sided tape you used to secure your fender strap. Also, will the rear fender support a passenger's weight with the fender strap/strut installed.
VROD
mikemc 04-07-2004 09:22 AM
Punisher,
I did the same on my pulley. I ended up wrapping the rear of the frame with bubble rap and 100mph tape.
VROD,
I was told that the rear fender strut will support a passenger, but I wouldnít chance it. Especially being that itís a rigid, I donít want to tweak or bend a freshly painted fender.
SapperLohr 04-07-2004 09:51 AM
Originally posted by VROD
SapperLohr
VROD
3M makes it...I ll get the # off of it and post it. It is strong as hell, and leaves room for a very small amount of movement. It absorbs a lot of the vibration that would transfer through the fender and into the seat, from what I have heard. I find that a little bit hard to believe, since it is less than a1/4 inch thick, but we will see....
Magicman 04-07-2004 11:01 AM
Hi guys , I just stumbled on this forum and as I am well into the build of my Hardcore II looks like this is a good place to be. I actually picked up my kit during bike week from a dealer in orlando. I already have everything painted and are about 60% finished with final assembly. Plumbing and wiring being the bigest chores left. The kit I bought was mocked up at this dealer for display purposes and broken back down for me to transport home(Houston) I've already mocked it up and checked everything with only a few minor problems to address. Since alot of the packages were opened previously I am missing some paperwork on a couple of the items?? Did your come with anything (wire color idenity) for the headlight? 5 wires? Pretty much got everything else figured out but ya'll may be able to save me a little time if I find out which are which on the headlight.
As far as mounting the rear fender I actually fabed a 2 piece bracket . The first piece about 5" long by 1 1/2" wide 3/16" .and welded it to the frame just behind the bar behind the Oil tank just in front of the fender area.Then the matching bracket sits on top of that one and is welded to the fender . I posistioned the fender and drilled two holes and bolted it down and used the lower hole as supplied. In the rear support area I drilled through the fender and tapped it to fit the rear turnsignal bolts to make this puppy rock solid as well as a dual purpose bolt. Will be hauling a passenger occasionally .Actually she's walking past me every night with P-Pad in hand trying to get me to hurry up.I'll post some pics soon as I get a little time. Oh also interested in what everyone paid as I noticed there was quite a difference quoted from different dealers. I paid 12,500. Could have ordered one cheaper but a bird in the hand is worth cash to me.Hate waiting for anything.
mikemc 04-07-2004 11:34 AM
Magicman,
Sounds like you got a great price, I paid $13,400 for mine. Did you get directions with your wire harness?
Fatkao 04-07-2004 02:10 PM
Thanks Sapper, MikeMC and Punisher on your postings. They were all very helpful...
I ordered my HCII back in October before teh price change. I ended up paying just over $12K for fully polished kit but had to wait until the first of March before I got the kit. (Long story) Without any bike building experience the bike was really not that difficult to build. I finished my mockup in about three nights. The toughest part was to get the rear wheel to fit in the frame. I had to take quite a bit of spacers off (over 1/8th inch). Of course along the way I did a few stupid things: Cross threaded my rear axel because the frame cutout was too tight, almost messed up my front fork by putting the spacers in the wrong sequence, and use the bolts from the Revtech engine crate instead the chrome bolts for mockup, and found out the bolt size is different so everything is off by 1/8th of an inch.... Just to name a few. I did get my frame powdercoated and actually got it back within 4 days. Everything is bolted back on to the bike now (Spent quite a few hours last Friday, Saturday and Sunday) and all I have left is wiring. The tins are getting painted and the painter kept on complaining about how bad of the finish the fenders and tank are. I am glad he is not charging me more for the work.
I should have the bike all bolted up and running in the next two weeks. (I hope) I will take some pictures and post them on the thread soon. Thanks again for all the interesting postings.:D
