Go Back   Club Chopper Forums > GENERAL CHOPPER TALK AREA > Chopper Builder's Log > Hardcore II/Outlaw Builds
Replacement peg rubbers?
DNA Wishbone Replacement Kit customer bikes
Last Post: JC
Last Post: wrenchy
Last Post: tukindubs
Chopper build finally road
  #346 (permalink)
Old 05-30-2004, 08:43 PM
Punisher's Avatar
NIMDA
Send a message via Yahoo to Punisher
Originally posted by tobor
I dont have a Hard Core but am runnihg a BDL.
I was told by by cal custom to put the small washer in between the stator and the stator housing and the large between the 1in offest insert.
Heres a pic of the washers..
Tobor, thanks for the info.
I am sure that if I should ever get anything back from the painter, Ill put your info to use.
and to all that have posted the pics with info, You guys coulndt help out any better!! (unless you are comming to my place to do it for me)
Punisher
PUNISHER
  #347 (permalink)
Old 05-31-2004, 06:15 AM
tobor's Avatar
Bike Year, Make, Engine: o4 BlackCloud 113ci Ultima El ,Prowler6
LOL... At least you guys got a group buikding Hard Cores, I'm all by myself with this Black Cloud...
But still getten good help from cool peeps on this board
I never make mistakes. I thought I did once but I was wrong.
  #348 (permalink)
Old 05-31-2004, 07:13 AM
Indy's Avatar
Bike Year, Make, Engine: Hard Core II/75 Sportster XLH
PCM
Hi guys, got a question for you. Regarding the Power Control Module. On the copper stud the 12 ga. red wire (in kit) to + side of battery, correct? Does heavy "All Balls" 8" cable go from the starter to the copper stud also?
Frank
  #349 (permalink)
Old 05-31-2004, 09:51 AM
Punisher's Avatar
NIMDA
Tobor, I though that I was the only one building the HCII till I posted about it. Now, and this is a good thing, they are coming out of the woodwork... Give it time, I am sure that there are others building that beautiful kit!!
Punisher
PUNISHER
  #350 (permalink)
Old 06-01-2004, 12:19 AM
Bike Year, Make, Engine: 2002 Softail 88B, 2004 Hardcore II 100c
Send a message via AIM to BigRock4545 Send a message via Yahoo to BigRock4545
So there is a spacer that goes between the stator and stator cover? Did everyobe else do this? I am at a point where I can put it on or leave it off, I am just curious.
Thanks,
Rock
  #351 (permalink)
Old 06-01-2004, 01:46 AM
Indy's Avatar
Spacer
Hey BigRock I put the spacer on my build. Read this thread. It will answer your question.
STATER help.....
Frank
  #352 (permalink)
Old 06-01-2004, 02:48 AM
mikemc's Avatar
Bike Year, Make, Engine: 2007 Road King Custom
BigRock4545,
I didn't use a spacer between the stator cover and spacer. I thought that it was only needed if the stator cover would rub against the stator. I have around 500 miles and no problems.
  #353 (permalink)
Old 06-01-2004, 11:09 AM
SapperLohr's Avatar
Bike Year, Make, Engine: Custom Chopper/Home-made
I forgot the spacer for the stator cover on my final build, and test drove. Oooooops. I rubbed the stator wires in two, and had to replace the stator.
I talked to the guy the other day, and found that he hasn't had any more charging problems---question--if left alone with those cut bare wires in there, will it mess anything else up?(regulator) Just curious
SL
W.J.Lohr IV
Drill Sergeant, U.S.Army
Airborne, All the Way
If we are the only intelligent life in the universe, at least there's a finite number of idiots
Just when you realize life's a bitch, it has puppies
  #354 (permalink)
Old 06-01-2004, 01:36 PM
mikemc's Avatar
I called Custom Chrome tech support regarding the Stator Rotor and the spacer. Tech support said if you got a SPYKE Stator Rotor, which is black in color you don’t need, the spacer. Spyke rotors are coned in so that a spacer is not needed.
And my stator rotor and staor did not come with any spacers.
What Stator rotor did you guys get with your kits and its color??
  #355 (permalink)
Old 06-01-2004, 03:53 PM
timebomb's Avatar
Bike Year, Make, Engine: 06 FLHX HD, twin cam A&B
Send a message via Yahoo to timebomb
they just told me the same thing mike...
he also said if you can spin the crankshaft without binding after it is impacted, you're good to go...
I have spyke alt cc# 28597
and stator cc#56229
  #356 (permalink)
Old 06-02-2004, 04:12 AM
mikemc's Avatar
timebomb,
That's what I have..I guess were good to go. As I said I have about 500 miles and I have had no problems with my stator or stator rotor.
  #357 (permalink)
Old 06-02-2004, 11:26 AM
Anyone,
How did you guys mount the choke knob? The directions in the coil package said " if you have a left side push pull choke you may need to relocate it". Is this true? Bill....
  #358 (permalink)
Old 06-02-2004, 11:41 AM
Timebomb or Mikemc,
What is the phone number to the custom chrome tech support? Bill
  #359 (permalink)
Old 06-02-2004, 03:04 PM
Bike Year, Make, Engine: 2004 CCHCII
edit
  #360 (permalink)
Old 06-02-2004, 05:28 PM
timebomb's Avatar
Originally posted by wildbill
Timebomb or Mikemc,
1 800 729 3332
