Submit Your Photos! |
Eyes
Posted On: 12-04-2019
Quick Hop
10-05-2004, 03:28 AM
NV
Bike Year, Make, Engine: 2007, Harley Electraglide Classic
Kevinhog,
That is an amazing scoot
Real good job on the paint bro  Personaly "I do not like flames on a bike" but to the exception of yours I really do like it. I'm sure it looks even better up close
Seriously speaking.......... after you finish you should send photos into "hot Bike" etc.........
Keep up the good work.....best of luck
Maldog
My other Chopper "Is a Chopper".
10-05-2004, 02:32 PM
NY
Bike Year, Make, Engine: '78 Shovelhead, 2004 Custom Hard Core II
Re: Re: Re: Re: Trail of the HCII Kit Bike
Originally posted by Punisher
No I hate to say it, but check your numbers. The neck is 36*+ 7* in the trees = 43*
A 50* rake would be insane!!!!! no way is the bike 50*
Punisher
Sorry, but I did check the numbers. look in the CCI catalog. Check out the frame alone in the catalog (not the kit), it has a 43 deg. neck + 7 deg. trees = 50 degrees total rake............the catalog doesn't lie.......
Save a life, adopt a Pit Bull
10-05-2004, 02:51 PM
PA
Bike Year, Make, Engine: 2007 Road King Custom
Re: Re: Re: Re: Re: Trail of the HCII Kit Bike
I was using the specs from the catalog also and that's what I thought were the true specs
10-05-2004, 04:45 PM
TX
Bike Year, Make, Engine: 2003 XL883, 2004 YZ250F
Gauge Question
If you've put gauges on your HCII, help me out -
I want a tiny oil pressure gauge that either mounts to the rocker box or directly off the case - Need suggestions and what pressure range your using on this motor.
I also want a tiny electric speedo w/ trip and odo that also mounts to the rocker box bolts or some other out of the way place. Plus I need to know what kind of sending unit you are using that is compatible with the RevTech 6 speed.
If you know the manufacturer or distributor part number, please let me know.
10-05-2004, 06:15 PM
NIMDA
MN
Re: Re: Re: Re: Re: Re: Trail of the HCII Kit Bike
I understand what you guys are saying, but you have to remember to believe nothing you read, and only half of what you see.
When my kit was new and just out of the box, I had the dealer put the angle guage up to my neck, it is 36*
Ive said what I saw, and what I know, if you choose not to believe me, that is your choice. Im not gonna continue to beat this dead horse.
Punisher
PUNISHER
10-05-2004, 06:46 PM
FL
Bike Year, Make, Engine: 2004 HCII, 110"
I'm interested in a small speedo/odometer setup as well. The ddcustom setup is about $400. I'm looking for something cheaper. I need to have it on my bike next Tuesday for the title inspection. So any help is appreciated!
10-05-2004, 07:41 PM
TX
wdglide: Ive been looking around and found this neat little unit distributed by Custom Chrome - its a MSB digital speedo - here's a link
http://www.sculpturecycles.com/a-Ele...MSB-speedo.htm
I wanted a oil indicator, trip/odo, and speedo - and this unit looks like it could take the place of all and more
It has LED indicators integrated into it - heres what I'm thinking - I could use a LED as a oil pressure indicator to take the place of the oil pressure gauge - no readout, but I would know if no oil pressure, right? Somebody correct me if I'm wrong.
Does anybody know what kind of speedo sending unit the 6 speed tranny uses? What's working for everybody?
10-05-2004, 08:25 PM
NV
Hey all!
If anybody has the correct wireing for the headlight please post it for me.
What I have does not seem right to me...
Also, if I hook up my blue wire (running light) to the front turn signal wires left & right the lights do not work?
If I leave the blue (running light) wire off all the turn signals work fine????????
Maldog
10-05-2004, 08:45 PM
TX
Bike Year, Make, Engine: Hardcore 2
Just finished mounting my front wheel (this time without breaking anything  .
I also cut the front fender, and relocated the mounting holes so it would set closer to the tire. I plan on removing the rivets, and filling in the holes with a little weld, so it will look smoother.
Posting more pics.
PsychoJester
10-05-2004, 09:01 PM
TX
You all might have noticed I've been posting a lot of pics. I hope it doesn't seem like to many. Me and my wife do photography on the side, so there is always a camera ready somewhere. Plus I figure maybe these will help someone with there build. Because man sometimes I can read something a hundred times and it still doesn't make sense
(maybe I'm di5lex!c).
PsychoJester
10-05-2004, 09:26 PM
NIMDA
MN
Have you looked at the pics of completed bikes?? I think somone here in the thread has analog guages that are SWEET!!!! and not that expensive.
Punisher
PUNISHER
10-06-2004, 03:27 AM
NV
Well I figured some of the headlight wireing out except the small yellow wire that is just in a loop! where does that go??????
Also the brown & black wire for the headlight running light,where do they connect??????
Even with these wires off all of my lights work, including brake,turn(front & rear)headlight(high & low) and starter.
Any help!!!!! I would like to get the headlight running light hooked up
Maldog
10-06-2004, 07:28 AM
VA
Bike Year, Make, Engine: 05 HCII, 87 FLHTC, 00 XL1200C and others
-ohcysP
I for one enjoy the pics keep them coming.
Just dislexic another,
Lane
Life's a shit sandwich. The more bread you got, the less shit you got to eat...
10-06-2004, 08:06 AM
PA
Check out this web site for the speedo mount www.ddcustomcycle.com and ask for Dave. This is where I got my mount and cup with all the hardware.
10-06-2004, 08:30 AM
PA
I just uploaded new pics of the speedo, speedo mount and my bike into the gallary.
I know this question has been asked before but how do I upload photos so that there posted onto the threads?
Mike
