Pushrod u still on here?
Last Post: fifty
Posted On: 04-03-2020
Seen the new Harleys?
Posted On: 03-31-2020
Old 03-28-2010, 09:28 AM
Bugnasty's Avatar
Bike Year, Make, Engine: 2006 DNA Softail, 95 Evo
Send a message via Yahoo to Bugnasty
My Budget Bagger Build
I just got my frame, a softail bobber 200. Bought the rolling chassis. I ordered directly from the vendor and did run into some issues. But in the end I got what I wanted. Now I am on a tight budget, but then who isn't these days lol. I have never built a bike before, but with luck, I will have this built soon. My plan is to build a bagger/chopper. I want the fairings and bags. With a rake of 36 and trees at 6, this is becoming an issue. Most fairings are for normal rakes. I have already picked out several parts I will work on getting soon. And once I do start the build I will post pics here. So if anyone else is building the same frame, I would love to share notes along the way too.
Bugnasty
aka Rob
Old 05-08-2010, 08:16 AM
Bugnasty's Avatar
Ordered the motor today from Robs Used parts online. They had a 1340 Evo fully rebuilt with S&S parts and a 6 month warranty. The hard "priced" parts are now bought. Now for all the small things.
Old 05-08-2010, 08:51 AM
post pics
Old 05-08-2010, 09:07 AM
Bugnasty's Avatar
Pics will be posted once the motor comes. I am getting very eager now that the frame and the motor are taken care of.
Old 05-08-2010, 09:17 AM
swank's Avatar
Bike Year, Make, Engine: '05 aih texas chopper, '06 Street Glide
Not trying to advertise for the guy, cause they were not too polite to me when I went in------but-----if you need parts locally while building, there's this place called "Bob's Cycle" at 39th st and University Dr in Phoenix, just of the I 10, guy has parts stacked to the ceiling!! New and Used for the tight budget. Just a thought since your local.
Booo-Yaaa!!
Old 05-08-2010, 08:21 PM
Bugnasty's Avatar
Thanks, I will check it out.
Old 06-06-2010, 09:33 AM
Bugnasty's Avatar
Ok here are the latest updates. I got the motor in last week. Placed it in the frame for looks right now. I need to get the hardware for the mock build. I loaded the pics to my folder. Just have to figure how to put them here.
Old 06-06-2010, 09:37 AM
Bugnasty's Avatar
Anyone have a clue on these? I think one goes to the forks. The other?
Old 06-06-2010, 09:42 AM
Bugnasty's Avatar
I think I am to take the caps off here and replace them with the above pic caps?
Old 06-06-2010, 09:44 AM
Bugnasty's Avatar
Here is my motor. Looks like I got some polishing time ahead of me. LOL
Old 06-06-2010, 09:53 AM
Is the rolling chassis your avatar?
Originally Posted by bugnasty View Post
i just got my frame, a softail bobber 200. Bought the rolling chassis. I ordered directly from the vendor and did run into some issues. But in the end i got what i wanted. Now i am on a tight budget, but then who isn't these days lol. I have never built a bike before, but with luck, i will have this built soon. My plan is to build a bagger/chopper. I want the fairings and bags. With a rake of 36 and trees at 6, this is becoming an issue. Most fairings are for normal rakes. I have already picked out several parts i will work on getting soon. And once i do start the build i will post pics here. So if anyone else is building the same frame, i would love to share notes along the way too.
Bugnasty
aka rob
if it is- it seems to have a great agressive stance. Did it come as a complete roller?
I'm a bit surprised that for such a mild neck rake(36) you have quite a big rake in the tree(6)- which must make your trail to be in a rather short range, but hopefully not less than 2''.anything less- you might face a high speed wobble . Check it out.
Have you thought to have the bags/ fairings to be easily taken off- so you would have the best of the 2 worlds- a nice clean chopper and( with bags/fairings on)- a touring bagger?
Just a thought or two.
Old 06-06-2010, 10:31 AM
Bugnasty's Avatar
Yeah I want the bagger look, but the chopper looks real cool too. I have to set it up for the wife to be able to ride along aswell. LOL.
Old 06-06-2010, 10:32 AM
If the upper tree is a pinch/clamp type...
i think i am to take the caps off here and replace them with the above pic caps?
did those caps come with the kit. Or you bought it in hopes to improve the look of the fork?
Your upper tree might only allow you to use the traditional hd setup in the top tree- that hex bolt you already have- which serves as the plug as well as tightens the leg to the tree from the top.
But if your upper tree is a pinch/clamp type- you can use any plug you want- but for that 2-hole one you need a special wrench and in the process of tightening the plug- you might scratch the hell out of it- not to mention strip those holes.
Also-i'm not even sure what the right one on the picture is?
Good luck
Old 06-06-2010, 10:35 AM
Nothing wrong with that...
yeah i want the bagger look, but the chopper looks real cool too. I have to set it up for the wife to be able to ride along aswell. Lol.
for me- i sit on the single seat of my chopper, fire it up, drop a tear and tell my wife:'i'll miss you, babe...' and down the road i go...alone.:lol:
Old 06-06-2010, 02:00 PM
Bugnasty's Avatar
The top of the trees are solid. No hole for the forks to come thru, only recess up into. The caps came with the kit. I just dont like the current setup to work. It looks unfinished at best. But yes, the trees have a hex setup to pinch the fork into place. So I can use any cap... hmm. Ok thanks Stein.
