Wcc parts wanted
Last Post: wcb007
Last Post: CIC2016
Last Post: SKT
Posted On: 01-26-2020
Last Post: SKT
Last Post: SKT
Old 06-06-2010, 03:11 PM
Pretty sure the thing on the right is a decorative cover for the steering head bolt in the center of the top tree.
Old 06-18-2010, 04:28 PM
Bugnasty's Avatar
Bike Year, Make, Engine: 2006 DNA Softail, 95 Evo
Send a message via Yahoo to Bugnasty
Been searching all over for the mounting hardware kits. Where do I find them?
Old 06-18-2010, 06:01 PM
JBob's Avatar
Is that the Long n Low roller from ACM?
J-Bob
"I reject your reality and substitute my own."Adam Savage
Old 06-18-2010, 09:54 PM
Bugnasty's Avatar
The roller is from Demons.
Old 06-18-2010, 10:26 PM
You want to look long and hard at shocks if you want to run that as a bagger.. Softy shocks suck by design anyway. To add all that extra weight you will want GOOD shocks... Just a heads up to help you out down the road.
Old 06-19-2010, 05:00 PM
rotorcowboy's Avatar
I built a bagger softail, I went with http://www.worksperformance.com/html/home.html
they have softail shocks for the heavy boys and they work great.
Old 06-24-2010, 09:57 PM
Bugnasty's Avatar
Does anyone know what neck cup setup I need for this frame? I got a set up but it doesnt seem to fit. There is a tab on the bottom of the neck that wont match up with the cups. Would that be an internal stop tab?
Old 06-24-2010, 10:33 PM
Bugnasty's Avatar
and a look at the lower trees....
Old 06-25-2010, 03:56 AM
robystyle's Avatar
It looks to me that the neck cups are built into the frame.You will need the bottom fork stop that bolts onto your lower triple tree and the tab on your neck will ride in it.I think i got a fork stop around here some where will have to look if interested shot me a pm.So all you need is bearings and races and the fork stop for your tree
Old 06-26-2010, 10:58 PM
Bugnasty's Avatar
Ok, races installed and everything fits great. I still need to get the fork stop part, but that solved that problem. Thanks Robstyle.
Old 07-10-2010, 05:28 PM
Bugnasty's Avatar
Got the fork stop in and installed today. I put it all together and seems that there is still a large gap in the trees. Both the nut and the main shaft are bottomed out, still a bit of play enough to be incomplete. Is there supposed to be a spacer/washer under the bottom tree to take up some of that slack?
Rob
Old 07-10-2010, 09:59 PM
no spacer on the bottom usually if internal stop, a dust cover on the top though...
Old 07-12-2010, 09:02 PM
Bugnasty's Avatar
So after doing a search, I find that the stem is about 1/2inch too long. Now I gotta find a shop that will cut it for me.
Old 08-29-2010, 02:57 PM
I had the same issue with my trees, paid a machine shop 35$ to shorten the stem but it was still 1/4" to long they wanted another 35$ to shorten again. I used an additional aluminum fork stop on the trees and it fit's perfect, I asked several members here and some said to machine it others said use the spacer..
Old 02-08-2012, 07:28 PM
Bugnasty's Avatar
Ok, Update time. I have the transmission now, Revtech 5 speed. Waiting on the 3.5inch Ultima Belt drive being shipped now. Fenders also. Starting to look for mounting hardware... Do I get a kit or just go to a dealer and buy a bunch? I am so stoked, its starting to look like a bike now.
