Ultima 113
revtech to baker trans swap
Last Post: bjh
Posted On: 05-30-2020
Posted On: 05-29-2020
Last Post: juanba
Posted On: 05-27-2020
Old 04-01-2008, 07:15 AM
Originally Posted by pushrod243
good luck with your build definitely beefeir than what you had
Careful with that statement, there are those that fly off the handle for stating that!!!
Old 04-01-2008, 07:21 AM
Slikvik's Avatar
Bike Year, Make, Engine: S+S 113 inch
UNC sooks
After chasin for some allen cap head 3and a half inch 5/16ths UNC 18 tpi decided to make my own ....hahahahahah great fun ...after talkin to an engineering works oo dont do that stuff mate is it for an antique tractor or summat ....worra good laff I nearly shit ......so made me own ..
all screwed up nice and tight now ........caused me some shit this offset but looks to be worth it
Good fortune on the road
Old 04-01-2008, 08:01 AM
Slikvik's Avatar
Wheres Mr Wizzer
Toooooooo much rear mudguard ( fender to you guys ) where's me wizzer
Old 04-01-2008, 09:19 AM
custom j's Avatar
Bike Year, Make, Engine: twin cam 1450
looking good ave you decided on paint yet ?
Old 04-02-2008, 04:38 AM
Slikvik's Avatar
More I rekon
Still needs moore cuttin offa the fender wanna see more of the 250 tyre
goin with some 10 inch rise mini apes I rekon home made bars just not working tank is the bollox .....
comin on slowly .......
No idea about paint ......no money so will have to be rattle and shake ...every part on my build so far is a deal or a swap or a trade with a bro ....
just found a big chunk a chequerplate in a skip ( dumpster to you guys) behind a machine shop, just right for behind the gearbox to mount my oil filter and elecrtic gubbins.....
Hark i can hear me wizzer ..........calling the fenders name
its cuttin time ............
Old 04-02-2008, 06:54 PM
rf1 rf1 is offline
nice bike, I love that frame.
Old 04-05-2008, 09:14 AM
Bike Year, Make, Engine: 1999, DNA 250 SOFTAIL, 1340 EVO
Send a message via Yahoo to skybobber
Originally Posted by Slikvik
hey something just dont look right I have 4mm clearance each side of my swingarm which all bolts up and is fine but I am just not happy about the bearings in the swingarm they just dont look like thay are fitted correctly in the dna pictures I have found
am I going mad .....or just got it wrong check out the pics below and chuck you 2 pennies in the water ....
so waddya think
Hey Slikvik !!!
I had to use (TWO .025" shims) Total of .050" on the RIGHT HAND side between the Swingarm and Frame. May be different fit on your Frame.
Old 04-06-2008, 11:53 AM
Slikvik's Avatar
Kool too kool
Looks like you got it fitted about right, I have my swingarm torqued and with the shocks removed if you lift the swingarm to the top of its travel and let it fall it takes a second or two to reach the bottom of its travel, wich I use as a good fitment guide ........kool dude
I woke up to 4 inches of fukin snow and shivered me nuts off in my garage .....really not happy
Old 07-16-2008, 03:50 AM
Slikvik's Avatar
Got Work Got Parts
Well after a dry spell got a months work so new parts ........
http://farm4.static.flickr.com/3239/...2d177c.jpg?v=0
may
http://farm4.static.flickr.com/3232/...16d2da.jpg?v=0
july
Hydraulic clutch , hotch bars .........gonna cut and lengthen
just cuttin some struts and bendin steel .....heat and hammer always works
Kinda hot rod style ....depends on what parts i can find,beg,steal,make,
just got some jbrake hydaulic clutch and brake handlebar doodads 1 chrome 1 polished ......strip one or chrome the other decisions ...decisions
Old 07-16-2008, 05:20 AM
justin caise's Avatar
UhhhhI'm confused...
PM sent.
Your car should be old style
Your clothes - rather new
Your chopper a tasteful mix of the two.
(Yeah, I just made that up.)
Old 07-16-2008, 03:15 PM
hi slikvik , whats the dimensions on your frame , the bars you got on there did you make or buy ? i like them , your frame looks the same as mine
Old 07-17-2008, 01:54 AM
Slikvik's Avatar
Specs Top job
FAT TIRE (240-250)
SINGLE TUBE
SOFTAIL STYLE
HEAVY DUTY FRAME
42 Degree Rake.
2" D.O.M. Tubing.
4" Stretch on Back Bone.
6" Stretch on Single Downtube.
Single Heavy Duty Downtube.
No Centertube Design.
Swingarm for wide rear wheel.
(240-250 fat tire)
probably the best made frame I have ever made a bike outta everything lines up perfectly ....1st time ever ......bars are home made ...and due for some cutting today ....pics later ....
Old 07-17-2008, 04:02 AM
choppedcadillac's Avatar
Bike Year, Make, Engine: 04 BigDog, 69 Shovel, 78 Superglide
Originally Posted by skybobber
Hey Slikvik !!!
Look at this picture and see where the belt rest against the lower part of the soft tail. This is a wear spot area where your paint will be rubbed off after a few rides and hitting bumps. Notice on a stock soft tail this area is flattened to eliminate the waer area. I built one of these frames and after powercoating and paint, I was not happy with this immediate wear spot. You're at a stage in the build you can do something about it now. Take a look at a stock soft tail, yours, then figure out how you're going to eliminate that problem. Its an eye sore. Every time I walked around my bike once it was finished, I couldnt see anything else but that area! These details determine the quality of the frame. To me, DNA frames are cheap. No offense to your project. I wouldnt use another.
Old 07-17-2008, 05:04 AM
Slikvik's Avatar
Cant see the picture dude
repost it so I can check it out
cheers
Old 07-17-2008, 05:53 AM
cheers
'I was referring to the pictures in post#22
Where the belt is resting on the lower portion of the swingarm/softtail...take a marker and draw down both sides of the belt...you will se where the belt will take the paint off when the swingarm moves up and down...another problem area with these frames is the front control mounts...not all are designed to bolt flat to the bracket...be sure to mount what you're going to use before powdercoating..just lessons learned...you'd figure a manufacturer would work the details out but as I said..its just a basic frame..thats all
