Go Back   Club Chopper Forums > CUSTOM BUILDERS/DISTRIBUTORS > DD Custom Cycle
Last Post: axeychrome
Teardrop Gas Tank Replacement
Last Post: R1_4Life
Posted On: 10-22-2020
Posted On: 10-21-2020
New CFL acquisition...
Posted On: 10-18-2020
Old 10-17-2006, 04:36 PM
Awsome builds
Hi DD
just wondering are you using the Legend air on the bikes you dropped onto the ground? im having are hard time deciding on a Hard or Low Life frame its my first bike
any thoughts?
Old 10-17-2006, 06:06 PM
ddcustom's Avatar
CC Member/Builder
Bike Year, Make, Engine: 2003 DD Custom
I use the legends system at the rear and the Tricky air system at the front - two separte compressors, completely two separate systems. They both work great. Your call.
Please let me know if you have any other questions. The legends is a bit bouncy, on the Tricky you can adjust the dampening by adjusting the rate of release for each canister - pretty neat.
Take care,
Dave Dupor
www.ddcustomcycle.com
Old 10-17-2006, 06:09 PM
ddcustom's Avatar
CC Member/Builder
The legends frames are great, structuraly and very precise interms of engine / trans alignment. The frames cannot rest on the ground without modification - they are not meant to. Since it is your first build, it is your call, comfort with the lowlife, or back pain with the hardlife - they are both great iun my opinion. You could do the hardlife with a spring seat as your suspension and it would be just as good.
Let me know,
Dave Dupor
Old 10-17-2006, 06:12 PM
Bike Year, Make, Engine: 100" Chopper, '56 FLE PAN
dd,
Got any good leads on small compressors?? Building an air system on my bike.
Thanks,
Scott
Old 10-17-2006, 06:18 PM
ddcustom's Avatar
CC Member/Builder
On my builds I have used Legends for the rear and tricky's for the front. They are basically the same air compressor - different solenoid valves. I would try looking into the air ride technologies (they are car specialists) they are a bit larger but much better in terms of recovery and efficientcy. AIR FX has a new system that I would like to try soon - they have a larger compressor as well, along with the Platinum series sold by MC Advantages.
Take care,
Dave
Old 10-17-2006, 10:30 PM
Thanks for the quick reply Dave
I Like the look of the Hardlife swingarm looks awsome i love the Element bike they built. How is that you get the Frame on the ground?
Is that the same system that Matt H uses on his Lowlife frames? Im sure he used an inverted Perse fork on Chingon
