Go Back   Club Chopper Forums > CHOPPER SHOP/TECH AREA > Custom Seat Builders & Leather Workers Forum
New In Wisconsin
Last Post: CorvetteMongo
polishing tips...
Last Post: Mojorising
Open primary
Posted On: 06-20-2018
Wiring Issues, or Not?
Old 12-10-2006, 01:58 PM
rastoy's Avatar
Solo seat shock angle
What's the most drastic angle (in, under seat) that a solo seat shock can be mounted and still work?
Nevermind, you're hopeless.
Old 12-10-2006, 02:03 PM
Pure Kustom's Avatar
Bike Year, Make, Engine: 2003 Pure KustomŽ Harley
5 degrees from vertical is what I tell my customers, with my springs. 10 degrees maximum
Old 12-10-2006, 02:12 PM
rastoy's Avatar
Darn, guess I need to come up with another plan. Thanks.
Old 12-10-2006, 02:15 PM
I would think you could go like 30 degrees and still give you some good bounce. No?
Old 12-10-2006, 02:16 PM
i think you can go much further than what pure kustom said, he mentions SPRINGS. with a shock, you can go much further, how far i dont know, but ive seen pics with them at some pretty big angles.
Old 12-10-2006, 02:43 PM
I would not go farther than 20 degrees. If the springs are not very strong you could bend the rod and damage the seals
Old 12-10-2006, 03:20 PM
Bike Year, Make, Engine: 07 Road Glide -07 spec Const shovel
What are you trying to do? I'm guessing you need to make a little mounting plate to adjust where the springs attach to the seat.
Old 12-10-2006, 03:34 PM
rastoy's Avatar
This is for my Matchless (see my gallery). I'm changing the rear fender and I thought it would be nice to have some spring on the seat (it's a hard ride).
Springs on a normal solo seat are wider than the rear and it would look goofey sticking out so I thought a single shock (center) might just work. The problem is mounting it in front of the fender creates the angle issue. Nothing is ever simple.
