Last Post: Southpaw1746
Last Post: Ragnar1970
Ultima 113
revtech to baker trans swap
Last Post: bjh
Posted On: 05-30-2020
Old 07-29-2018, 10:43 AM
Bike Year, Make, Engine: evo
pink slip
hi bought a harley hardtail frame i got the frame that was no problem but the pink slip was sent to the UK but never arived, frame i believe is 1955 ish got side car mounts,being over here and not done this before is there any advise, was sent regestererd mail so not the guy who sold me the frames fault,but without pink slip bit buggered
Old 07-30-2018, 09:25 AM
pink slip
well the only idea i can come up with is buy another frame with pink slip, as long as its before 1969 i believe there are no numbers on the frame
Old 08-02-2018, 12:36 PM
If the frame has no numbers, you can see about titling it as a custom build.
That might be your only way to use/title it.
Old 08-04-2018, 06:05 AM
to regester here in uk i will either need a 1955 pink slip,or some 55 crank cases, otherwise the reg number will start with q which you dont want in the uk as causes loads of problems, so unless i can find a 55 pink slip, will have to find cases
