Swing Arm bushings question
starter problem
Posted On: 11-16-2019
Ultima Fat Bastard
Last Post: Timfromflorida
Posted On: 11-12-2019
Project Blast!
Old 04-15-2017, 06:16 PM
Twin cam offset pulley
Does anyone know if ultima makes a offset pulley for on the sprocket shaft of the new twin cams,Vulcan sells the adapter ring to use the 3.35 open belt with the evo/pre 2006 twin cam but I can't seem to find the offset pulley with the new spline design anywhere on the web
Old 04-15-2017, 08:06 PM
Sorry I meant the adapter let's you use the open belt meant for evos and pre 2006 twin cam, with the post twin cam bolt pattern on the engine
