Troubleshooting a Baker OD6
Last Post: jaybird74
Open Primary belt question
Last Post: loren
Last Post: bigtwin100
need custom oil tank
Last Post: peach64
Old 03-05-2012, 06:51 PM
Bike Year, Make, Engine: 2012 Custom Rigid, 127CI Ultima
Originally Posted by cfl4rat View Post
All RE frames come stamped with #'s on the front motor mount
Ah I understand what you are saying, the serial number of the frame. When you said VIN I lost you but I am tracking what you are saying now. Thanks!
I am seeing some big differences between my frame and RE frames but once I find out who made it I will post it up.
Sua Sponte
De Oppresso Liber
Video of my bike here --->GREYBEARD
Old 03-07-2012, 08:38 AM
Here are the most recent pictures I just got from the builder. We are waiting to get the front fender painted and on, also waiting on a VIN from the DMV, they have to take the front end aprt and the primary and repaint it flat black over the gloss black.
Sua Sponte
De Oppresso Liber
Old 03-08-2012, 03:32 PM
TimNY's Avatar
Bike Year, Make, Engine: 2011, Homebuilt custom. S&S 96". Baker 6
Looks great.
Awsome job.Love the blacked out look !
The rims kick ass .
Very nice.
Old 03-09-2012, 08:20 PM
Ok so its almost done, headed to Wilmington tomorrow to take her for a ride... Just got a picture with the front fender on it. I am on the fence on this one.. what do you guys think?
Sua Sponte
De Oppresso Liber
Old 03-10-2012, 09:28 AM
vin1800's Avatar
Bike Year, Make, Engine: 2012 Harley Street Bob
Front fender looks good, Leave it on.
Old 03-10-2012, 08:46 PM
Thanks! Took it for a ride today... OMG this mutha pulls hard! Just waiting on DMV paperwork, new starter, paint on the trees lowers headlight and bars, and to recoat the exhaust... not sure what they used but if it was powder coat it flaked right off...
Sua Sponte
De Oppresso Liber
Old 03-11-2012, 12:44 PM
Update: here are a few more pictures from yesterday...
Sua Sponte
De Oppresso Liber
Old 04-30-2012, 12:19 AM
Final Pictures as it sits...
Sua Sponte
De Oppresso Liber
Old 05-18-2012, 01:11 AM
Ok so after putting 400 miles on it I have had a few break in problems. The speedo bracket and the horn bracket both broke. They were very thin aluminum brackets and the vibration from the 127" did a number on the brackets. Both broke at the bolt hole that connect to the part. I was thinking a thicker gauge aluminum or even steel along with a rubber o-ring bushing with do the job.
Another big problem is the ignition switch. Once I get the bike back from the builder I will be on the third one in 30 days. Both have burned out with big white puff of smoke along with it. As I was putting in the trailer I noticed the fender mount on the right side was backing out. The builder called me today and told me that it was stripping the bolt right out and to fix the problem they are going to be putting a fork brace on it to stop this from happening again.
The other big problem is the battery continues to die. I have had to put it on a trickle charger to give it enough juice to start it up. Once I let it sit over night (not even 12 hours) it is dead. Once I jump it or put it back on the charger, it is good to go. The longest distance I have ridden it without stopping for gas or cutting it off was approx 125 miles. I have read that it could be a ground issue or a wiring problem but I am not trouble shooting it since the builder is liable for the problems.
I am just putting all of this out there to get any advice from other builders and enthusiasts. Do I need a fork brace? I don't like the way they look and really don't want one if I don't need one. If the bike was a few years old I would have fixed these problems myself but since it is a brand new build and this issues are a park of the break in period I didn't try to fix them myself.
Thanks everyone in advance for reading this and throwing you opinions and advice out there!
Sua Sponte
De Oppresso Liber
Old 05-18-2012, 01:23 AM
low, mean and clean... cool chopper! hope you'll get your problems solved asap, the help squad will jump in, don't worry !
Old 05-18-2012, 01:46 AM
Thanks Bullet!
Sua Sponte
De Oppresso Liber
Old 09-24-2012, 08:54 PM
I have recently worked out all of the bugs and she is running like a dream... here is a quick video ... don't mind the plastic bag tied to the frame but I had no other way to get my drink back to the house.
http://youtu.be/UhS2KzCzLCo
Sua Sponte
De Oppresso Liber
Old 10-06-2012, 12:34 PM
Also an update... read up and got advice from several different builders on the East Coast and they all recommended to double ground the bike so I did... Check it out... no lag when starting it even turns over hard and starts up right away when before it was turning over slow.
Sorry I didn't update my bikes slow revolution fix before. I double grounded the battery using large grounds and it does not hesitate at all. I have attached two pictures. One clean and the other with the grounds circled. I had a single ground to the starter before that was about half the size of what I am using now. Just replacing the grounds I have seen a significant difference with how fast the bike starts up.
Sua Sponte
De Oppresso Liber
Old 10-06-2012, 02:07 PM
300build's Avatar
Great looking bike but I'd lose that front fender...doesn't fit the minimalist rear fender and the general style of the bike IMO.
Old 10-07-2012, 12:46 AM
That is actually the plan if I don't sell it but I will be going with a wider front tire in 23"
Sua Sponte
De Oppresso Liber
