Wtf!??? Gorilla clutch!
Last Post: longnlow
uh oh...chain
Last Post: magnum45pete
shock bolt softail
Last Post: kidchop
Last Post: jaybird74
Old 01-25-2007, 07:49 AM
Bike Year, Make, Engine: 2005 custom
cfl primary spacer?
Have a new cfl 2up frame coming and trying to buy parts before arival. Does anyone one know what the primary spacer offset needs to be when running a 200 rear wheel. 1/2in, 1in, 1 1/2in ?
Old 01-25-2007, 08:24 AM
BigMikeSimpson's Avatar
Someone else will need to verify this...
I am almost certain that there is no primary spacer or offset and you need a 1/2" offset sprocket for the trans.
Read this thread... Lots of info there...
http://www.clubchopper.com/t19950.html
Old 01-25-2007, 08:46 AM
SOCAL's Avatar
Bike Year, Make, Engine: Sucker Punch Sportster in the works.
none, 1/2 in offset trans sprocket 23 tooth
Garage Built, Sucker Punch Style.
Old 01-25-2007, 11:07 AM
yeti12's Avatar
What So Cal said
Old 01-26-2007, 09:15 AM
When you build a CFL you appreciate the WCC mindset on fundamentals.
Like everyhitng (mostly) fitting together right.
Old 01-26-2007, 10:28 AM
Bike Year, Make, Engine: 1999 Rigid S&S 113, 06 CFL, 73 HD FLH
There right. Use the correct offset for your Trans. sprocket (pulley). As far as the motor, I had a shit load of primary spacers from my last bike. Do your mock up and put a straight edge on the front of your clutch basket and motor pulley. Now the real test is torque your primary bolt on the motor and (left had thread) nut for your trans. Once you have them torqued to your specs, place your straight end on the front of your two pulleys and see if your still on. Good luck.
