Starter torque dpecs
Hunting an AIH Wiring Diagram
Last Post: Bostonjake01
Posted On: 02-15-2020
Posted On: 02-14-2020
Old 03-05-2019, 07:30 PM
Maustarman's Avatar
Bike Year, Make, Engine: Ultima 127
Gargantua! First Full Build -Ultima 127
I just picked up a gigantic project (at least for me)....
Frame from Straight-Up Choppers
Engine: Ultima 127c.i
Trans : Ultima 6 speed
CA Compliant 127 motor-6 speed RSD with-330 rear tire... Carb Compliant ignition module, full wiring harness, air ride suspension with compressor. 2+ inverted forks, 40* on the neck and 6* on the trees.
twisted spoke front wheel, 21x4 in front 18x14 twisted spoke rear wheel with Avon Cobra tires.
I found this chopper project where absolutely everything was in boxes....the previous owner ordered almost everything to put together a chopper but never started it.
I'm not new to customizing bikes but my forte is custom painting and I mess around with everything else.
For sure I've never fully built anything other than my 9yo kid's mini chopper lol... So, Ill be having LOTS of questions for you all in here if that's OK. @shovel52 has already been providing some advice *thank you.
I've started to mockup all major components in the last couple of days just to have a rough idea of what is missing.
in all honesty, I don't even know where to start so any guidance will be immensely appreciated.
Mauricio
Picture here:
https://www.dropbox.com/s/vafou2njug...%20PM.jpg?dl=0
Old 03-08-2019, 07:58 AM
Maustarman's Avatar
Ok... was trying to muck up a couple more things and now I feel like I’m missing a part...
Please the picture here https://www.dropbox.com/s/lzhvc8qola..._2432.JPG?dl=0
So, we are looking at the couch here but the is a whole in the primary that has nothing coming through from the starter side ...
Isn’t there and shaft of something coming from the starter ?
I’ve been going through all the boxes but can find anything like it that could go there
Old 03-08-2019, 06:16 PM
Yes , that is where the starter jack shaft gear sticks through, it pops out and en gauges the larger ring gear..first install the starter and that small gear installs from this side..here is a picture of it..
And then there is a support piece that installs over the end to stablize it..which in your case may just be the primary cover..You also have the bushing missing.
https://www.google.com/search?q=harl...KnoHQ5BC_-kCM:
Looking at your battery box, which is kind of small...the beast likes lots of food when cranking...I went through a long trial with batteries, and ended up with
an oversize lead acid battery..the lithiums ..not hot enough...I had to slightly modify my box..something you should investigate before you run out and buy
something too small..Here is the one I ended up with..take the dimensions and see if it will fit..looks like you may be able to cut the back of your seat pan and make it fit..
https://www.throttlexbatteries.com/product/hdx30l/
Old 03-10-2019, 09:32 AM
Maustarman's Avatar
Thank you shovel2
I’ve found in the box of parts some bushings that are supposed to go there but it seems a jack shaft kit needs to be in the shopping list.
Battery: thanks for the heads up ... darned! I was totally thinking of the lithium batteries because you can get a lot more power in a smaller size battery.
What was your experience with the lithiums? Not enough cranking amps ?
Old 03-10-2019, 04:33 PM
I found that they would give an initial kick, but if she doesn't crank the first or second time then you are about to run out of juice.I have heard other guys in the forum say the same thing..
Pushrod, here in the forum is a parts dealer, and he said that when he started dealing with the Lithiums, that he got a lot of complaints from customers and a lot of returns..You can always try
one and do the same thing if you are not satisfied..I love my big old lead acid battery now after being stranded a couple of times...The lithiums are high too..3 or 4 times the price..but that's why they make them, some people don't have the room..
I actually tried making a lithium motorcycle battery, after my ANTI GRAVITY lithium went out, I opened it up...ordered a bunch of individual cells off of ebay and
soldered them all together , exactly like they had them, and I think it would have been great except that all the cells were garbage, and the amp hour rating was way over rated and the chinese guy selling them was just trying to dump a bunch of old stuff, and I fell for it...he ended up giving me half my money back...$30,,what the heck, for that kind of money something like that is worth a try..That thing would barely hold a charge much less crank a v twin.I was actually able to get about 10 more cells in the casing than they had, too bad it didn't work out.................................just keep in mind that you are going to be riding ....the BEAST!
Old 03-10-2019, 07:21 PM
How much room do you have under your primary cover? do you have the room to mount your oil filter? That's where mine is mounted..On the Shovel I mounted it in front lower of the engine..
Old 03-16-2019, 08:47 AM
aussieprostreet's Avatar
Bike Year, Make, Engine: PROSTREET 23" FRONT & 18" 300xREAR
NICE!!!
Very similar setup to mine in some ways
What are you doing for a rear brake?
Old 03-19-2019, 09:06 PM
Maustarman's Avatar
Hey Shovel
I dont think I have enough room under the primary cover... the oil filter bracket is already set up in the front/lower part of the engine.
Old 03-19-2019, 09:11 PM
Maustarman's Avatar
Originally Posted by aussieprostreet View Post
NICE!!!
cool! Got any pictures? IM starving for ideas!
Rear Brake..... good question... it will be mounted to the rear axle and I need to weld a bracket for the stay.
Now, the questions do I ad a brake rotor to the left side or do I mount it to the right side using the sprocket as a dual function ...Sprocket + Rotor.
Wondering if the chain lube might affect the brake...
Old 03-21-2019, 02:10 PM
mmmmm the sprotor / Sprockster setups are a bit 50/50 it seems, some people have no issues & others wont go near them
I am also running a right side drive gear box so I have to sort something similar out myself, I have the same style swingarm so finding a caliper bracket is tricky
The best solution I have found would be a 2000 - 2003 sportster rear bracket & caliper to suit, there is plenty of different brands / options so you can look around but the Performance Machine bracket is one of the nicest, I do have all the part numbers including just the bracket alone part number but here is the link>
https://www.performancemachine.com/m...e-caliper.aspx
You can see it is basically just a left side mount bracket that runs parallel / horizontal with the swingarm so its perfect for what we need, a simple tab for the bracket to locate & move forward & back along with chain or belt adjustment is all thats needed, only issue that is no worry at all is the bracket hole for the axle would need to be taken out from 3/4" to 1", easy enough to do
Other option is to fab an aluminum bracket yourself along the same lines, I have some billet aluminum pieces laying round that would do the job nicely so I might make my own bracket>
Old 03-21-2019, 07:57 PM
Maustarman's Avatar
along the same lines, I have some billter aluminum pieces laying round that would do the job nicely so I might make my own bracket>
Yes, Iíve decided itís not worth taking any risks and going to go for the left side mount with a rotor.
I already have the mount for the axle all I need is to weld a tap and get the stay bar.
https://www.dropbox.com/s/66xyuw90jr...%20PM.jpg?dl=0
Old 03-21-2019, 08:09 PM
That rear brake you have is for a sprotor setup which suits a sprocket not a much thinner disc
Might have to sell it & buy a proper brake bracket n caliper as I linked above
Old 03-21-2019, 09:06 PM
Maustarman's Avatar
Crap ... didnít think about that...
thank you !
now Iím not sure what Iíll do ..
Old 04-02-2019, 02:41 AM
How are you going with it all? & what did you sort out with the rear brake caliper?
Thought I would list the rear brake caliper part numbers that I have found so far>
Performance Machine 00-03 rear caliper bracket>
0023-1526XU-B Black
0023-1526XU-CH Chrome
0023-1526XU-P Polished
HHI 00-03 Sportster rear caliper bracket
RBSPCC101 Chrome
RBSPAB101 Black
PM brackets listed here for reference>
https://www.webike.com.mm/products/21692386.html
Old 04-06-2019, 10:49 PM
Maustarman's Avatar
Thanks man!
I think for now I’m going to stick to the sport or although I’ll be welding a tap in the left side tus I can install a disk brake if the I don’t like the Doroteo ...
What are you doing for brake lines ?
