Go Back   Club Chopper Forums > GENERAL CHOPPER TALK AREA > Chopper Builder's Log > Carolina Customs Builds
Posted On: 11-29-2021
21" Doom Front wheel needed
Last Post: LorenzoHD
Posted On: 11-26-2021
Evil Bitch
Last Post: Choppa
Brembo brake ID
Posted On: 11-24-2021
Old 04-09-2006, 07:01 PM
Bike Year, Make, Engine: 2007 ASPT 250 Carolina Custom Softail
Shots of Carolina Custom Build
Here is my latest build using a Carolina Custom 250 Softail Chopper, with American Suspension Phantom Front end, the favorite Revtech 100" 4X4 and 6spd Tranny , Airtail Suspension, Kustomwerks Front and Rear Fenders, Wire-Plus harness and Dakota Digital Speedo-tach display,etc. Any feedback would be greatly appreciated!
Here is my attempt to load pictures.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 04-11-2006, 02:53 PM
Does anybody care??
Old 04-11-2006, 03:25 PM
PACO's Avatar
PIX loaded OK............yes we all care...........I like the lines of what you got going on........not to up & out. Looks daily ridable. Please continue!
PACO
Old 04-11-2006, 03:30 PM
Looks good but I'd loose the fiberglass pan. They flex to much, or so I've been told.
Old 04-11-2006, 04:12 PM
LUCKYDEVIL's Avatar
There’s no were for it to flex?
S8tenbikeWhat color you going with?..
Old 04-11-2006, 04:15 PM
LUCKYDEVIL's Avatar
rlwjr13, Your right i now see the fender is mounted to the swingarm...
Old 04-11-2006, 04:18 PM
CENJIM's Avatar
Looks like you've got it pretty well mocked up. Any problems so far?
Old 04-11-2006, 06:55 PM
So i guess you guys recommend a sheetmetal pan? The base color is black, but i do not know what i am going to do on the tins. Thanks for the responses
Old 04-14-2006, 11:34 AM
Has anyone heard of this new powdercoat process? The can mould the frame before powdercoating. Should turn out good.
[IMG][/IMG]
Old 04-14-2006, 11:37 AM
CENJIM's Avatar
That would be a definite advantage for powder. Let us know how it turns out.
Old 04-14-2006, 11:43 AM
I sure will. It is supposed to be a high temperature material used on planes and marine applications.
Old 04-23-2006, 06:34 AM
Markee's Avatar
One mile from home.
It's probably "Lab Metal". Used as a filler in high temp applications.
Old 04-23-2006, 11:03 PM
36Indian's Avatar
Bike Year, Make, Engine: 36&48 Chief,'98CustomSofttail,'54Triumph
talk to your powder coater and use what he recommends, make sure the stuff your using has metal in it to conduct current flow. Evercoat metal to metal was a hot item for a while but it's aluminum & fiberglass, handles the heat great, but if you use it in a valley area dosn't always get a good coating because of metal around the valley conducts current better, attrating the powder before it gets to the low areas. Also if using Iridescents & multiply coats it doesn't coat evenly, and makes light spots. An all- metal filler works best. I've heard of Lab Metal but haven't tried it yet. But with a black powder as long as its super smooth it will look good, I think blacks are the easiest to shoot.
Old Schooler//LIVE to RIDE
Old 04-23-2006, 11:23 PM
36Indian's Avatar
P.S. I like the set up on your scoot. It may not be the flashiest on fri. night but you'll be out ridden for many more hours with that rake and softail on Sat. & Sun. no accomadations for old lady???? or 1 nighter?????? Don't forget you can powder the fenders & tank, and paint pins or panels on top now or later. Black with Prism in it ( metal Flake) makes a real sweat look. You can use alot or a little.
I like a little less than a lot!!!!! Multi color sparkel in the sun light nice extra closs at night. Clean simple and sharp, just like your build.
Old 05-29-2006, 08:40 PM
1st attempt at paint!
Here are some pix of my 1st attempt at paint. Let me know what you think
