Merch 560Q cam specs?
Last Post: tat2dale
Posted On: 10-16-2021
Posted On: 10-15-2021
help with ultima RSD6
Posted On: 10-14-2021
Fender grommets
Last Post: muddychops
Posted On: 10-13-2021
Old 11-23-2007, 10:25 PM
Bike Year, Make, Engine: 93 Sportster - Chopd, Stretched n Raked
Does anyone here know much about Girder front ends?
Thinking about getting one but don't know fuck all about them.
Can you adjust them for rake?
My current front end on my Sporty is a regular 4 over narrowglide, no rake in the trees.
I have 40 degree neck rake and have some flop at low speeds. I measured it and I figured I could go 3 - 5 degrees in the trees.(and kick the front end out further)
Fuckin raked trees seem expensive and hard to find narrowglide ones - every body wants you to go mid or wide. I want to keep it narrow.
I thought at this point I might as well go with a springer or a girder(preferred)if I could find a decent priced one. Always wanted a girder.
Just don't know fuck all about them. Want to make sure I fix the trail so that's why I was asking about adjusting the rake. I know with a springer it's done with the rockers
KongBastard
Old 11-24-2007, 04:14 AM
Bike Year, Make, Engine: sporty -an evo or two - da pan.
Send a message via AIM to bite me Send a message via Yahoo to bite me
The rake and trail on a girder front end does not change as much as the front shock system expands and contracts under load. This is because the contraction/expansion point of the front end is clustered around the stearing head and not between it and the front axel. Its a geometry thing. Everything else is the same as far as options for rake and trail fit up. You need to stay in the sweet spot with those numbers. Structurally they are a triangulated design so if properly built they should be stronger and lighter than the other two types of front ends. Rake and trail do not affect the spring action of the front end as much as they do with springer and hydraulic front ends. You need three inches. Even with that said you can adjust that on a girder by building new lead links. I have never run one on a frame that has been raked.
Old 11-24-2007, 04:48 AM
Bike Year, Make, Engine: 100" Chopper, '56 FLE PAN
In my personal opinion a good functioning girder should be custom built for a specific bike. The connecting links are typically around 4.25" long. Changing the connecting links only does minor changes in the trail numbers. If you have flop then you want to reduce trail and off the shelf girders have little room to shorten the links. On my bike the rake is at 42 and the main leg of my girder is right around 43. With a little time on the drawing board you might be able to find a girder off the shelf that will work for the trail numbers you want.
Some of the nicest looking girders are made by George Counes at Spartan Frameworks,$2,100 raw. Gambler makes girders buy I don't know how well that company is operating since it change of ownership.
Then you have Jaxons ISG fork which is an improved version of the Harmon spirder. He does awsome work and his narrow version is tight and kickass. His is around $1,200.00. RoadRat.biz. He will take all the measurements that you give him and build it custom to your bike. He has guys riding around on bikes with less than 2" of trail and they love them.
Building one yourself is not that big of an endeavor if your handy.
Old 11-29-2007, 12:05 PM
jsdiamond's Avatar
Some girders have an adjustable feature which is really just a set of holes where you mount the side rocker-links on the trees. The forward-most holes kick out the rake a few degrees; while the nearer ones lessen it.
Old 11-29-2007, 03:00 PM
DC ORIGINAL's Avatar
This is similar to how the new RMD Billet girder is set-up. Adjustable from around 3-7 degrees depending on where you bolt it up. This thing is like nothing else out there. No steel, no tubing, no bending and no welding. Completely machined out of billet aluminum and uses a Penske shock!
http://www.rmdbillet.com/girder.html
Old 11-29-2007, 07:58 PM
jsdiamond's Avatar
Holy-moly, that is beautiful!
Old 11-30-2007, 01:15 PM
Yea, it's definitely a piece of art. A alot of machine hours.
Old 01-23-2008, 09:13 AM
PWH PWH is offline
Bike Year, Make, Engine: working on it
That's nice but, I don't care for the 'thick' legs.
Old 01-23-2008, 09:35 AM
sportyracer2's Avatar
Bike Year, Make, Engine: mulitple
Seems like I've seen that front end before on an R-1?
Old 01-23-2008, 05:23 PM
bluefin907's Avatar
Bike Year, Make, Engine: custom chopper 124
Send a message via AIM to bluefin907
I like the look of those girders. I would use something like that for sure
Movin on up to the east side
Old 01-23-2008, 06:21 PM
Bike Year, Make, Engine: 09,S&S 96"Chop.
Does anyone here have any detailed drawings of girder forks,or does anyone
sell plans,as they seem to command big money?
Old 06-22-2008, 07:26 PM
Bike Year, Make, Engine: Shovelhead CFL in the works
the chopper builders handbook sells a CD that has a step by step guide to building a girder. Plan on doing one myself.
Old 06-24-2008, 05:49 PM
rottenralph's Avatar
Bike Year, Make, Engine: 1993, harley, xl1200
It certainly is a beautiful front end. 3500 bucks is a little much for my budget but they certainly don't look cheap at all.
Rottenralph 1993 1200 sportster super sport with JET stage 3 heads, 10.5 to 1 wisecos, s&s with thunderjet, dyna ignition, and too much more to list. . If it aint broke get a bigger hammer .
Old 09-15-2020, 07:08 AM
[quote=DC ORIGINAL;696735]This is similar to how the new RMD Billet girder is set-up. Adjustable from around 3-7 degrees depending on where you bolt it up. This thing is like nothing else out there. No steel, no tubing, no bending and no welding. Completely machined out of billet aluminum and uses a Penske shock!
Does anyone know where there is a used RMB Billet front end for sale (like the black one) thanks
