Go Back   Club Chopper Forums > GENERAL CHOPPER TALK AREA > Chopper Builder's Log > Buell/XL Builds
Worth Chopping?
Last Post: PC6399
Ultima 113
Last Post: Southpaw1746
Posted On: 06-03-2020
Last Post: Ragnar1970
revtech to baker trans swap
Last Post: bjh
Posted On: 06-02-2020
Old 12-29-2008, 10:43 AM
ImageOne's Avatar
Bike Year, Make, Engine: 68 Triumph TR-6
Ironhead Digger
So here is my new project, it will also be my entry for the Horse's ACO in May, so i got a LOOOONG way to go both literally and figuratively.
R4YL 3.0 >>>> AUGUST 5-7, 2011 <<<< OHIO KENTUCKY INDIANA
http://r4yl.blogspot.com/
Image One High Performance Art
Custom Paint & Pinstriping
Old 12-29-2008, 10:44 AM
ImageOne's Avatar
Well the UPS dropped off an X-mas present today! couple days late, but i'm still pretty f-n stoked! Had to run out to the shop and throw it up against the bike to check it out in all of its leeeengthy glory.
Got my frame jig pretty well finished up, got my black plumbing pipe ordered (*joke*) and just about ready to start cutting up some sh*t! Frame will be out 3 and down 1 or 2, single downtube. what ya think? too long?!
Springer upon closer inspection is stamped Columbus Custom Manufacturing, C-bus OHIO! how cool is that, time to do some research...
Old 12-29-2008, 10:46 AM
Should be a cool project. I really dig the springer you scored.
Old 12-29-2008, 10:54 AM
That's gonna be Killer!!!!!!!!!!!!!!
Old 12-29-2008, 11:08 AM
ImageOne's Avatar
thanks guys got some cool ideas, can't wait to start
Old 12-29-2008, 12:02 PM
Merlin Hawaii's Avatar
DON'T WORRY - BE HAPPY
Man, it looks great the way that you have it set up in the pic
NOT too long - the proportions are just right
She's gonna be low, though
"Hula Baby"
Old 12-29-2008, 01:43 PM
That is one badass springer! Massive!
Old 12-29-2008, 02:13 PM
jsdiamond's Avatar
Looks cool, man.
Old 12-29-2008, 04:43 PM
i like it!......................
Old 12-29-2008, 08:32 PM
nice iron.....................
''From start to finish its all chopper''
Old 12-30-2008, 08:17 AM
jasonrenda's Avatar
Bike Year, Make, Engine: 04 FXD, 91 XL Chop - fucking me again
damn joel - you going to do paintwork AND enter the horse aco? nice man!
hope ohio streets are wide for turns.....my green sporty had a 43 degree rake and it took me 25 minutes to turn around.
it was a banner fuckin year at the bender house
Old 12-30-2008, 10:22 AM
ImageOne's Avatar
haha, its gonna be a busy winter! you get your stuff sorted out yet? you got a spot whenever you want it
Old 01-05-2009, 07:55 AM
ImageOne's Avatar
Got a little work done on the rear fender tonight, if you look back, you can see how far off the radius is on the fender. Started using the 2x4 method, and it was working but it was slow going, and it was hard to tell how much movement you were getting, but it was gettin work hardened so i knew it was moving. Decided i would anneal the metal to get it back to a workable condition.
acetyline only, leaves a sooty layer, add oxygen, get a good heating flame and burn all the soot off.
Then chucked the fender in the vise, clamped the side and then pulled on the other side to achieve the same effect that the 2x4 method uses. Worked my way around a few times.
Getting better, annealed again, more bending, and here we are.
Fits real nice both radius and profile with the tire. using the vice left a bit of scaring on the metal, but nothing significant. A little dolly work and it should be good to go. Gonna take about an inch out of the center of the fender so that it matches the width better, but i'm p'retty happy with how its turning out so far.
the fleet:
http://c2.ac-images.myspacecdn.com/i...fe8c34b641.jpg
Old 01-05-2009, 08:10 AM
jasonrenda's Avatar
nice Joel
not to thread-jack but i got the sporty nearly done. wired and all. fired up but needs tuning. just trying to decide on metal fender or plastic one. dont want to send em to you in seperate batches. once i decide that i'll send e out to ya. your fleet is looking good!
Old 01-07-2009, 06:23 AM
ImageOne's Avatar
got some more work done last night. Here's the fender after the first cut, with tape to mark the width to be removed.
little more hackin' action
Then some grinding to clean up the mating surfaces.
couple tacks and check the fit.
man i need to take the real camera to the shop, close up of weld, not bad for a snot box on sheetmetal. Obviously needs ground and smoothed, and probably a little more weld in a couple spots, but not bad for the first time.
