Go Back   Club Chopper Forums > GENERAL CHOPPER TALK AREA > Chopper Builder's Log > Buell/XL Builds
2004 Bourget Retro
Last Post: rstarost
Last Post: rstarost
New Forum Member
Old 09-05-2008, 01:12 PM
Yeah I've been using American Classic Motors since getting dicked around by KC INTERNATIONAL and they seem to have their stuff together so far.
Signature
Old 09-05-2008, 06:58 PM
motoscott311's Avatar
Bike Year, Make, Engine: 2003 Honda Shadow
Hey man - What length front end are you using? STOCK or 2" over?
Old 09-05-2008, 08:02 PM
I went with a stock, I almost got a 2 over but decided to use this one instead.
Signature
Old 09-06-2008, 04:02 AM
Tim B's Avatar
i have the nemesis 250 frame and i used a +4 front end on it and i think i should have used a +6 you might find out that a stock front end is too short
Old 09-06-2008, 05:42 AM
Nah this is the Weapon frame, it's -2 on the upstretch. Other than that the specs are the same as your Nemesis.
The way I have the tank set makes it look less "prostreet" huh? I'm kinda going for an extreme bobber look.
Signature
Old 09-08-2008, 01:12 PM
Tim B's Avatar
what are the measurements of your oil bag ;length/ diameter?
Old 09-09-2008, 05:16 AM
It is 5" diameter and 11" long. I had to modify it to work but I got the tank at a really cheap price so it was worth the extra effort. I also didn't want to use a smaller bag. I've got it mounted now, I'll post pictures of it later today.
Signature
Old 09-10-2008, 03:00 PM
Tim B's Avatar
please do i'd like to see how you mounted it although it probably won't help me because i'm making my oil bag out of copper pipe but i'd like to see it anyway. thanks
Old 09-11-2008, 01:23 PM
Tim B's Avatar
do you think that will be strong enough? i'm making bands that will go all the way around the tank and mounting it in 2 places
Old 09-11-2008, 06:16 PM
I think so, I plan on welding small gussets to the bottom of the frame tabs when I tear everything back down. But I hear you, it can never be too strong. That's why I'll probably make a rear mount for it too, I'm just still trying to figure out how I want to go about doing it. Probably just a center tab, so it will have 3 mount points
What have you guys found for battery boxes? I may fab one, but if there are some nice ones out there for cheap I would rather just buy it.
Signature
Old 09-11-2008, 07:27 PM
Tim B's Avatar
go on the ********* web site and look at how they did it that might help you out. my thought about the way you show it in the pictures would be the vibration and the wieght of the oil moving back and forth in the tank and eventually straining your mounting tabs to the point of breaking. but look at the way they did it (*********) and that might work for you
Old 09-15-2008, 06:38 PM
Tim B's Avatar
i welded up a nice battery box out of stainless but i have to make a new one because i'm going to have to lay the battery on it's side with the 6" oil bag
Old 09-16-2008, 05:18 AM
Thats why I mounted my bag so tight to the frame, I hope I have enough room to mount mine rightside up and have a little room left over for fuses and such. Have to wait and see. With sealed batterys these days mounting on the side is no big deal though right?
Signature
Old 09-16-2008, 01:11 PM
Tim B's Avatar
as far as i know that's right
Old 09-20-2008, 10:10 AM
started mounting the seat, I wish it had more roll in the back. I may not use it, I'm still deciding. Note the BIG BOY springs.
Signature
