New In Wisconsin
Last Post: CorvetteMongo
polishing tips...
Last Post: Mojorising
Open primary
Posted On: 06-20-2018
Wiring Issues, or Not?
Old 04-05-2007, 12:14 PM
strit11's Avatar
Bike Year, Make, Engine: CHC Shovelhead
Wiring Diagram for Triumph w/ Magneto?
Anyone got a good wiring diagram for me? I've got a 70' T120 that I'm running a Joe Hunt Mag with, headlight, tail/brake light and ignition switch, no battery. What I need to know is exactly what I need as far as components(diodes, rectifier?,regulator, ect.) and where the wires go. I have a updated solid state rectifier I was planning on using. Any help would be great. Thanks
Old 04-05-2007, 12:16 PM
strit11's Avatar
oh yeah
I also need to know where to wire in a on/off toggle switch for the lights, I will also run a mag kill switch from it. Thanks
Old 04-05-2007, 08:28 PM
36Indian's Avatar
Bike Year, Make, Engine: 36&48 Chief,'98CustomSofttail,'54Triumph
The absolute cleanest way to wire it up is use something like a Sebring Box or (battery eliminator type unit) and for non mag ignition a Honda 160 coil. The light toggle if you can hide it somewhere on the light houseing ( bottom?) and that way you only run 1 hot wire to the bucket, and but your Hi-Low next to it. May need ground line depending on light wattage.
Wiring:: the 2 stripped wires from alternator to sebring box, from box red wire to head light & hi-low & brake& tail.
white would normally go to coil, green to ground. if not using a battery elimanator then 2 alt wires to retifier, capacitor off 3rd prong on rectifier, rect. & capacator must have good ground, same prong as capacitor line goes to lights and zener diode . the capac. and diode absorbe high voltage off rectifier so you don't blow bulbs at anything over an idle. Send your fax # a picture is worth 1000 words very simple to do. Sebring type box worth the money.
Old Schooler//LIVE to RIDE
Old 04-05-2007, 08:35 PM
36Indian's Avatar
Your mag kill switch is a ground button or switch. 1 wire from the mag to a kill button on the handle bar, but then your ignition is always hot and anybody can walk up and kick start your bike. Either hide a 2nd ground switch or get a key switch from a lawn mower shop for mag that grounds out when off.
Old 04-20-2007, 05:40 PM
36Indian's Avatar
So STRIT did the diagrams apply to what you have? Hows the project doin.
