Last Post: chopperfugger
Last Post: juanba
Posted On: 05-27-2020
Rear wheel spacer
Posted On: 05-26-2020
Posted On: 05-25-2020
Old 01-13-2006, 03:47 PM
Bike Year, Make, Engine: 68 triumph 650 chop
Long story
OK here we go. Last time I rode my 68 Tri chop it ran great. That was in October( then it got cold). Belive it or not its Jan. and the temp. is near 60 not to shabby for Buffalo. Decided to ride You know get one in befor the snow fly's again. well after about the 20-25th kick I realise no headlight just a tailight. checked the battery (good ) checked the fuses( good )also power to the fuse box, checked power in to the tympunium (good)This is where my troubleshotting knowledge stops. any help ? Please... This can't be to hard only run a headlight and tailight Tymp w/boyer ign. where do I go after power in to tymp?
WWILD
Old 01-13-2006, 10:15 PM
36Indian's Avatar
Bike Year, Make, Engine: 36&48 Chief,'98CustomSofttail,'54Triumph
You didn't list the plugs? If you haven't checked its always good to pull the plugs, ground to head, kick and see if theres strong blue spark, if theres spark start checking fuel system. If no spark try a plug you know is good or use a carefully postioned screwdriver. Seems these new plugs foul real easy. Especialy the Bouchs. No spark with good plugs go to the coils 1 small wire post is hot, check with test light. '68 was transition year from positive ground systems and later yr changing to normal negitive grd. check battery for how yours was wired. If its custom wiring system I'd try getting juice to plugs and then trouble shoot the light cicuit.
Old Schooler//LIVE to RIDE
Old 01-15-2006, 04:35 PM
Problem solved
OK problem solved! Defective low beam headlight switch. This is the second one in 5 yrs. It's a typical e-bay low,high,horn,switch, dose anybody know of a better switch?
WWILD
Old 01-17-2006, 09:24 AM
36Indian's Avatar
O- OK, when you wrote 25 kicks even at 40deg, you've got problems beyond no light. When was the last time for a basic tune-up? Try split tip platuim plugs they help starting on low compression engine noteacably. The splitfires work good on the Tri.
Old 01-17-2006, 02:02 PM
My low beam is connected to ign. system, when I switched to high beam, the light turned on, it started on the second kick in the garage and the temp was 17degrees outside, maybe 34 in the garage i'm sure it's a faulty switch. thanks for responding I belive the problem is solved
WWILD
