Go Back   Club Chopper Forums > Painters/Seats/Chop Parts/General Distributors > Brian's Custom Paint
Last Post: GREENEDONNIE
Posted On: 05-16-2022
Last Post: OfficialBigDog
Posted On: 05-11-2022
Last Post: shinbentley
Posted On: 05-10-2022
Fender grommets
Last Post: muddychops
Posted On: 05-09-2022
Old 03-25-2012, 06:22 AM
Bike Year, Make, Engine: 2007 ULTIMA / 1999 HARLEY
Can U Powder Coat BDL Pulleys ?
I have a BDL I wanted to have the pulleys powder coated and my mechanic says the heat from powder coating will mess them up.
Is he right?
Do I have to get different pulleys?
Thanks In Advance.
Old 03-25-2012, 06:40 AM
I wouldn't think there is a problem. Most conventional PC is cured at 390*F. They do have a process that uses much lower temps for curing called photofusion which utilizes lasers for the cure.
Old 03-25-2012, 06:44 AM
my concern would be the thickenss ... powercoating can build up..causing the belt not to fit properly..& it may start to chip off after some time..I think anodizing would be better..
Old 03-25-2012, 06:56 AM
Good point although its usually only a couple mills thick. The other option would be to mask off the where the belt actually rides.
Old 03-25-2012, 06:58 AM
true ,,true..thay do have high temp tape just for that...I was thinking the OP wanted the whole pulley to have color...
Old 03-25-2012, 07:18 AM
i did mine in 2 colors without any problems.. just find a guy that does custom work for cars and bikes. a industrail powder coater will lay it on to heavy
