licanse plate for modified BDL Jacksaft cover
Last Post: CIC2016
BDL 3" open primary jackshaft
Last Post: CIC2016
5 speed trapdoor bearings
Posted On: 09-21-2023
Posted On: 09-20-2023
Posted On: 09-18-2023
Old 11-17-2011, 05:20 PM
flustered
just got my first chopper,2004 bigbear chopper venom.blown headlight cant figure out how to get to the bulb,does the front just srew off?
Old 11-17-2011, 05:53 PM
I think it is pry 1st and then screw (just like getting a girl to give it up).
Old 11-17-2011, 06:56 PM
evorider's Avatar
LOL Cowhunter...
Old 11-17-2011, 07:58 PM
You have to unscrew the outer ring some have a set screw on the bottom. Usually they are a bugger. I use an old rubber inner tube to get a better grip on it. Once you get the outer ring there will be an inner ring. usually these take a tool to insert into the holes in the ring to unscrew it. A small punch or pick will work. Oh and a lot of patience......
Old 11-18-2011, 05:49 PM
Lightnin'Larry's Avatar
Bike Year, Make, Engine: 2010, Brouhard Designs chopper, S&S124TC
On a side note, has the Venom you just aquired had the recall done on it?
"Don't worry about what people think; they don't do it very often"
Old 04-04-2022, 09:41 PM
Originally Posted by evorider View Post
LOL Cowhunter...
I had a lot of patience to do the same thing as yours, but badly it didn't work.
