Last Post: pop 28
Last Post: chopperdiva
Last Post: Green
starting issue
Old 08-30-2009, 03:38 PM
Bike Year, Make, Engine: Soon to be BBC Venom Chopper
Need New Battery for 05 Venom Chopper
My Venom came with a SVR14 sealed battery.
The bike has sat for long periods of time without much use.... I probubly should have had it on the battery tender. Its dead now.... wont even take a charge.
I know this is a sealed battery, but not sure if it is a dry cell or not. Need to get a replacement....would like a drycell or gel cell I'm assuming. What do you reccommend. Whats the safest from a sealed standmpoint... 100% leak proof. Don't know much about batteries... would think the dry cell would be the way to go??
I appreciate you help.
Thanks Ralph
Old 08-30-2009, 05:38 PM
CENJIM's Avatar
Ralph, I think that SVR14 is an AGM type battery.
AGM=absorption glass mat.
http://www.dcbattery.com/agmtech.html
Old 01-11-2010, 04:07 PM
jofishr's Avatar
Bike Year, Make, Engine: 2005 Venom 110
I just ordered this from Scooters Performance
braille battery
Item # b14115
I have not tried it yet, but i'm sure its gonna work and fit.
360 CCA
http://www.scootersperformance.com/partsbattbrcf.htm
Old 01-12-2010, 10:21 AM
Force's Avatar
Bike Year, Make, Engine: 04 Venom Pro Street, 06 Softail Deluxe
Send a message via Yahoo to Force
Braille..........
[IMG]http://i116.photobucket.com/albums/o2
/Shane_Force/2acrop.jpg[/IMG]
"127 cubic inches of Frame Crackin, Tank Splittin fun"
Old 01-14-2010, 02:07 PM
I had to replace mine also (2008 DA Chopper) kit bike. Battery was fine; but kept vibrating the wires loose with those captured nuts.... I put red locktite on them... Held them tite but then spun the captured nut and twisted the post on the ground when installing battery tender for winter.
My replacement is a harley battery... Same exact dimensions and CCA but now has drilled / tapped front mount posts instead of those top mounted captured nuts... Works much better....
