80-82 FXB belt drive compensator nut
Last Post: WTCHOP
Show us your bike!!
Last Post: WBGelbke
Happy Birthday Chopperdiva
Last Post: chopperdiva
Last Post: 250CFL
Old 07-06-2008, 08:53 AM
sactown_sled's Avatar
Securing timing rotor
Any suggestions on how to secure the rotor for the electronic timing module (Crane Cams HI-4) on an S&S 100? Is a single lock washer enough, or does it also need to be locktited? I originally followed BBC's instructions and just used the supplied allen screw to hold in the rotor, which resulted in the rotor coming loose under the timing module, and damaging both the module and sensor.
Old 07-06-2008, 09:37 AM
Merlin Hawaii's Avatar
DON'T WORRY - BE HAPPY
I use blue Loctite - no washer
I also use blue Loctite - with washers - on the sensor plate stand off mounting screws
Old 07-06-2008, 10:45 AM
gypsy chopper's Avatar
Originally Posted by merlinhawaii
I use blue Loktite - no washer
maybe im thinking wrong but isnt the stock bolt a hex head with the washer built in?
Old 07-06-2008, 10:50 AM
Yes, the stock HD bolt is a hex head
The Hi-4s come with an allen head socket cap screw (without a washer) to mount the rotor
Old 07-06-2008, 10:51 AM
so thats what that friggen screw is.
ok, never used it, always used the 2611b
Old 07-06-2008, 12:59 PM
Any reason to not use a lock washer and locktite with the allen screw? I am just a little paranoid after having to buy a new timing module to replace the damaged one.
Old 07-07-2008, 05:01 AM
i dont use lockwashers so i cant answer that. locktite yes.
but i have seen more rotors coming loose on this forum in the last 5 months than i have seen in 20 years so i would do something differently, now they are popping off left and right.
