Honda shadow spirit 750 rear disc conversion
Last Post: 2WheelsTherapy
S&S 113 Super G jetting.
Last Post: bugman53
Last Post: bugman53
uh oh...chain
Finished!!!!!!!!!
Last Post: nsdq3
  #391 (permalink)
Old 03-09-2008, 05:10 PM
LUCKYDEVIL's Avatar
He had a failure analysis done. BAD WELDS
  #392 (permalink)
Old 03-09-2008, 05:15 PM
Bike Year, Make, Engine: 100" Chopper, '56 FLE PAN
I don't have a dog in this hunt but it does upset me. Someone had to say that not chamfering was alright. "That will be just fine"
I do have to give the welder credit for being able to weld completely around the tube and not melt the razor sharp edge of the cope. That has to be a challenge. I sure as hell couldn't do it!!!
  #393 (permalink)
Old 03-09-2008, 05:17 PM
MechWerks's Avatar
In that picture, you can see the cutter marks still on the tube. A proper weld would have burned into most is not all of that tube wall leaving absolutely no recognizable cutter marks. There is hardly any weld cross section. If the weld had been the proper depth of penetration (correct root section) there would have at least been a wide area of weld breaks provided the weld had actually be able to split and more likely that that root section width would have been pulled out of parent tube or the tube itself would have failed in the HAZ (heat affected zone).
http://www.mechwerks.com/Coping.htm is an article from my website showing a tube cope being made, fitted and chamfered prior to welding. The thin sharp cope ends are removed to expose full end sections of the tube being welded. A cut away of a similar weld shows there is weld from inside the tube wall clear to the outside plus a reinforcement fillet. It that example were destroyed, I have no doubt that that weld bead would remain in one piece and surrounding tube metal would be failed instead.
MechWerks
  #394 (permalink)
Old 03-09-2008, 05:20 PM
MechWerks's Avatar
TIG welding is making a puddle of the correct material penetration and adding filler wire to complete the weld. To make a weld that does not burn into the edge of a tube you simply use the torch to melt the filler wire over the base material without forming a penetrating puddle...totally wrong way to weld...is not a weld...definately appears to be the process used on this frame.
MechWerks
  #395 (permalink)
Old 03-09-2008, 05:23 PM
gypsy chopper's Avatar
if it wasnt ground
  #396 (permalink)
Old 03-09-2008, 05:27 PM
Lightnin'Larry's Avatar
Bike Year, Make, Engine: 2010, Brouhard Designs chopper, S&S124TC
Hey Gypsy,
The place that you circled on the left, that's not bondo brother, that's the weld material itself.
Originally Posted by gypsy chopper
i dont see too much of anything except the line i drew inside the tube could be the edge of it.
but things like what i circled on the left, where bondo appears to go all the way to the tube itself...makes me wonder why. was there a crack or hole there the welder missed, big enough to stuff that bondo in, or was it ground to a point of NO WELD, or is that bondo smeared over from after the break, or the photos angle? all guesswork, & worth zero. but from the pic that should have been a big eyesore before the paint.
so...im not gonna analyze it like the zapruter film when the obvious answer is under the paint to confirm or deny.
yes rolling thunder has had more than one issue, as well as diamond, redneck, wwc, on and on.
"Don't worry about what people think; they don't do it very often"
  #397 (permalink)
Old 03-09-2008, 05:29 PM
the white stuff?
  #398 (permalink)
Old 03-09-2008, 05:31 PM
if it wasnt ground
  #399 (permalink)
Old 03-09-2008, 05:32 PM
The "white" stuff is light reflected off the metal from the flash on my camera.
the white stuff?
  #400 (permalink)
Old 03-09-2008, 05:34 PM
LUCKYDEVIL's Avatar
  #401 (permalink)
Old 03-09-2008, 05:35 PM
I call that soldering (did I butcher that one)
  #402 (permalink)
Old 03-09-2008, 05:36 PM
ok then, there is no way i would have guessed that. maybe all you guys got better monitors than me.
and im not trying to insinuate anything larry, and havent from the beginning, except that i hate single downtube frames because i think they are inherently weak BY DESIGN. i totally believe you may not have ground anything. but since its gone to court, as well as being beat on here....i dont mind playing devils advocate(pun intended)
  #403 (permalink)
Old 03-09-2008, 05:38 PM
In the pic above I only see a little HAZ area on top and maybe, just maybe a little on the bottom.
  #404 (permalink)
Old 03-09-2008, 05:43 PM
No worries bro, it's all good
  #405 (permalink)
Old 03-09-2008, 05:53 PM
CENJIM's Avatar
So when the weld analysis was done, did they strip off the paint and bondo, etc.?
If yes, do you have any pics to put up?
