Grumpys King Pins
Last Post: baltimorebiker
Last Post: K001
Last Post: SYDEFEX
Last Post: chopperfugger
Posted On: 04-23-2018
Last Post: EdCase
Old 07-04-2006, 07:56 PM
mack1212's Avatar
Bike Year, Make, Engine: 2005 venom chopper
simple way to change oil???
just lookin for the simplest and cleanest way to change oil. where to drain from?
05 venom chopper , RT 100.
Old 07-04-2006, 08:11 PM
ff154's Avatar
Bike Year, Make, Engine: 06' SuckerPunch 93" Shovel
I use one of these on my BBC Merc - works fine.
http://www.bikernet.com/products/viewsingle.asp?ID=51
Old 07-04-2006, 08:49 PM
flyinhawaiian's Avatar
I have an 05 Venom chopper. My oil tank does not have a drain plug like yours, I assume. I went out and bought a cheap wet/dry vac and modified the suction end of the vaccum hose using a pvc fitting to accommodate 1/4" clear tubing just a little longer than the depth of the oil bag through which I suck the oil out. It takes minute to get the suction going but once it starts you get all the oil out real fast. It is a bit more messy than having a drain plug because of the suction hose but the option of regularly disconnecting a oil line I feel is not a good idea due to the wear it will eventually cause the tubing fitting. I allow the the suction hose an hour or so over the vaccum tank to allow any excess oil to drain out of the hose.
I take off the oil filter with an oil filter strap wrench that attaches to a 3/8" ratchet. The strap wrench can be purchased at any auto part store. The single down tube and the lack of clearance between the filter and the engine case makes it difficult to use any other type oil filter wrench. Oil drip during removal? None. Once I get the filter loose I take a small plastic bag and wrap it around the filter for final removal by hand.
Good luck!
Old 07-04-2006, 09:11 PM
RippoDippo's Avatar
I unscrew the hole clamp and pull off the feed line
Old 07-07-2006, 10:20 AM
cowboy14's Avatar
Bike Year, Make, Engine: 2005, Venom
I Bought A Hand Pump From Harbor Freight For $10 To Pump The Tank, Then Open The Drain Plug In The Crank Case. Pump Works Great.
Cowboy14
