Last Post: chopperfugger
Last Post: juanba
Posted On: 05-27-2020
Rear wheel spacer
Posted On: 05-26-2020
Posted On: 05-25-2020
Pushrod adjust.
Old 03-02-2014, 11:25 AM
dropseat_bobber's Avatar
sled oil change
hi there, names cody, just got a 2009 sled bbc and im trying to locate the oil drain plug, ive looked all over under the bike and cant seem to locate it. any help would be appreciated, thanks
Old 03-02-2014, 02:57 PM
illclubyourass's Avatar
Send a message via AIM to illclubyourass
If you can't find it disconnect the lowest oil line and drain or extract the oil using something like this
Quick, Easy & Clean Oil Changes with PELA Products
Old 05-19-2019, 02:08 PM
I have a 2008 BBC Sled, I have the same issue. I was told to disconnect the bottom line to oil pump because there is no other drain from oil tank.I can't pump it out because the tank is REAL narrow about 1/2 way down inside tank
.......I'm still looking for other options if there are any.
