Oil Lines
Last Post: Maustarman
Posted On: 08-14-2019
Bars upside down
Posted On: 08-12-2019
Posted On: 08-10-2019
Last Post: donald branscom
Posted On: 08-09-2019
Project Blast!
Posted On: 08-08-2019
Old 05-05-2012, 09:37 PM
Bike Year, Make, Engine: Custom Bobber, 100ci ElBruto
Originally Posted by skylarbluepuppy View Post
well u can ohm the coil also can test ign module with test lite at coil
I am guessing I need a battery to perform the above tests?
What sort of outputs should I be looking for?
Cheers
Old 05-06-2012, 05:05 AM
Ok so this is where I am now..
New Ballistic Battery Ordered
Ordered "All Balls" Battery Cables 4-Gauge (Just in case the welding cables I have aren't upto it or crimped good, although they didn't melt or distort from what I can see).
Purchased a Starter Relay and will purchase a mini momentary push button switch to use as my primary start button..
For you reference here is my wiring diagram..
I just need to figure out where and how to incorporate the starter relay and push button switch and what gauge wires..
I would assume at least 10-12gauge from Relay to Starter Solenoid, and 14-16 gauge between Switch and Relay etc...
May need some help.
Old 05-06-2012, 05:11 AM
Razorback's Avatar
might want to check your regulator output. I just fried 2 batteries going to Leesburg bike fest the weekend. Put new battery in and in 20 miles it was toast.
Old 05-07-2012, 03:22 AM
That's got to be annoying!
Once I get the new battery I will run a test on the output at 2000RPM..
Old 05-07-2012, 05:06 AM
Razorback's Avatar
Put new battery in and put the volt meter to it it was charging at over 17. Put new Regulator on and every thing is back to normal.
On your grounding : I run ground from battery to frame from frame to starter. With basic wiring don't know that you need a starter relay. I run a wire from start button to starter.
Old 05-09-2012, 01:08 AM
I purchased a 5 Pin 30A Relay (Horn Relay) and Momentary Switch, I plan on wiring it up this weekend, but just want to ensure I am doing it right.
#30-- Power Keyed (only hot when ignition is on)
#87A -- wire from this terminal to small spade terminal on starter
#87 -- wire from this hot to headlight (this should cut hot to headlight when push button is pushed)
#85-- wire from this terminal to ground
#86-- wire from this terminal to start button
Am I on track? What about wire gauge..
