Last Post: Slik_one69
front Brake hose
Posted On: 02-18-2018
My Budget Bagger Build
Last Post: thefreeauction
Posted On: 02-17-2018
Posted On: 02-14-2018
Old 11-09-2010, 05:17 PM
Bike Year, Make, Engine: 1990, Harley Davidson, evo
evo 80 ci rebuild
i have picked up a andrews 23 cam kb pistons and drag specialties adjustable pushrods for my 1990 80ci evo
my case is leaking in the middle were you would split it at as well as were the shift peg comes through the primary cover.
i need a gasket kit or a list of the gaskets i need to make my motor leak free and at a the best price possible and were i can get them from any help would be great.
Old 11-09-2010, 05:19 PM
also the gaskets i need for replacing those parts this is my first harley motor build thanks for any help
Old 11-09-2010, 05:51 PM
I could be wrong but isn't that one of the years that had bad cases..when I say bad I mean bad castings, crap, junk..The cases should be replaced..
I could be wrong on this...sorry if I am.
Old 11-09-2010, 05:59 PM
Go to a Jap shop and get Three bond 1194 to put your cases together. this shit will seal up a loose pussy.
Old 11-09-2010, 06:00 PM
btw you realize you gotta split the cases to fix that right?
Old 11-09-2010, 06:31 PM
tat2dale's Avatar
Bike Year, Make, Engine: 2012 CFL , 2001 FXDXT
you are right about the year of the cases. They should be replaced. Bad castings/material.
Have you looked into the harley engine re-build program?
HEAVY METAL SAVED MY LIFE
Old 11-09-2010, 07:01 PM
the i read up on something about the harley engine re build program in hot bike i think but thats 3000 dollars and my case just started leaking
but were is the best place to get gaskets for my rebuild
Old 11-09-2010, 10:48 PM
BMdeckie's Avatar
Bike Year, Make, Engine: Various years of replacement parts.
I used Harley and James Gaskets for my rebuild on my 94' Evo 80". The Re-man program from Harley is total bullshit.....at least from my local Harley dealer. It is normally $2500 for the rebuild but but cowboy Harley here in Beaumont, Texas wanted another $1300 to take the engine out and put it back in. Even though the engine was already out of the bike they wanted me to put it back in before they started work on it. The rebuild gasket kit from Harley ran me about $80.
Mistakes: It could be that the only purpose of your life is to serve as a warning to others
Old 11-10-2010, 06:11 AM
80-80's Avatar
I paid about $3000 for a brand new motor from H-D including shipping, so unless you just want to keep your #'s I don't see a big advantage in the rebuild program. I'd do some research on the case issue if you don't have a porosity problem at this point I'd say you got a okay case, not all had problems.
Buy American, you may save an illegal alien's job.
Old 11-10-2010, 07:03 AM
If you've never used KB pistons,
make sure you get the ring gap correct.
Incorrect ring gap can cause major damage to the engine.
A little insight, .0065 per inch of bore.
Old 11-10-2010, 11:05 AM
ok thanks for all the help
Old 11-10-2010, 04:29 PM
what do u think of those pistons have u had any issues
Old 11-10-2010, 04:37 PM
Not anything I would care to use.
Basically it's a cast piston with a hypereutectic lid.
Forged is a much better option.
No problems but the cylinders get bored different than other manufacturers. Give the pistons to the borer and ask if he's fitted kb's before. The pistons will come with a leaflet explaining this, give it to the guy doing the boring.
Old 11-10-2010, 04:43 PM
Yes, I have experience with them.
I had a 350 Chev. that I took apart one time that the builder didn't file fit the rings and it lifted the tops off all 8 of them.
Not the only dealings I've had with them. Just one example of negligence.
