Posted On: 05-29-2020
Last Post: juanba
Posted On: 05-27-2020
Rear wheel spacer
Posted On: 05-26-2020
Posted On: 05-25-2020
Old 10-26-2009, 01:38 PM
Bike Year, Make, Engine: Harley 97 fxdl 1340
new hardcore II build
ive been running a 97 fxdl for 12 years and i fancy a change so i got me a santee single down tube 200 rigid im putting the evo engine in it ive bought a trk shift 6 speed soft tail tranny does the chain primary motor plate off the 97 fit the soft tail tranny i know the roller bearing in the motor plate is a larger diameter than the soft tail tranny drive shaft . i can see this is gonna be the start of many questions thanks for any help .proth the brit ...
Old 10-26-2009, 06:24 PM
winston chopper's Avatar
Bike Year, Make, Engine: 2005 CFL 127" elbruto w/ D carb, 6 speed
Most stuff for those type of frames is for softail parts. I guess you would have to have done it before to know for sure. Call HD they can tell you. If the bolts line up maybe you can get away with a different bearing for the trans shaft?
Dont piss your pants to see if your fly is open
Old 10-26-2009, 06:31 PM
The Inner primaries are different on a Dyna and a Softail. The bearing should have an inner race that is on the trannys mainshaft. That race will fit right in the inner primary bearing. The outer primary from the Dyna should be the same as the Softail. The Dyna has a notch to clear the swingarm which makes the inner different. I'm also not sure about the bolts on the inner primary that thread into the tranny case if they are in the same locations as the Softail. You could mock it up to see.....
Old 10-26-2009, 06:42 PM
SOCAL's Avatar
Cool another new HCII, just finishing mine. Welcome to the board.
Garage Built, West Coast Style.
Old 10-27-2009, 11:43 AM
hardcore II new build
Thanks for all the help guys its nice to know your out there i managed to put the dyna motor plate on to the motor tranny all bolt holes lined up but all together it didnt sit right in the santee frame it was high at the tranny and sloped towards the front engine mount i cant tilt the blck any further back which would put the tranny back on its mountings because of the seat post cant quite get in into my head why it should sit like that but there you go . thanks again guys ...proth
Old 10-27-2009, 11:46 AM
by the way socal nice chop ...proth
Old 10-04-2015, 02:11 PM
Just resurrecting a hardcore II been looking on the threads for info what a great bike this must have been summation special in its day can't wait to ride it
Old 10-04-2015, 03:03 PM
SOCAL's Avatar
2009, Man you have been away for along time.
