Grumpys King Pins
Last Post: baltimorebiker
Last Post: K001
Last Post: SYDEFEX
Last Post: chopperfugger
Posted On: 04-23-2018
Last Post: EdCase
Old 10-19-2009, 11:21 AM
Force's Avatar
Bike Year, Make, Engine: 04 Venom Pro Street, 06 Softail Deluxe
Send a message via Yahoo to Force
Having problems with battery or starter turning a 127 Ultima
I have an Ultima 127 built by SMW. I am having serious problems turning the motor over when I first try to start it. The motor turns over until it hits the compression stroke then slows to a stop even with a fully charged battery. I always use compression releases. I have also melted the positive terminal on 2 batteries just trying to start the bike. I have tried a stock HD battery that comes with the Softail Deluxe, the battery that came with the bike, and a brand new 270 CCA battery. None of them start the bike consistently even though they wereall kept on a battery tender.
Could this be a battery problem, starter problem, or bad or insufficient wiring to the starter?
[IMG]http://i116.photobucket.com/albums/o2
/Shane_Force/2acrop.jpg[/IMG]
"127 cubic inches of Frame Crackin, Tank Splittin fun"
Old 10-19-2009, 12:18 PM
check your connections, bad grounds are a killer.. Also, I would try and get the CCA over 300...
Old 10-19-2009, 12:22 PM
What size starter are you using? Battery and wires have to be of sufficient size as well as good quality connections.
Old 10-19-2009, 12:35 PM
DB DB is offline
Bike Year, Make, Engine: Shovel, Pan, Iron
Minimum 1.7 KW starter motor and Tod is right on the cold cranking Amps for the battery. Sometimes the jackshaft pinion gear gets stuck on the starter ring gear and you have to take off the primary plate cover and knock it loose.
Old 10-19-2009, 12:51 PM
Wrong info again. 1.4 will turn that motor with compression releases all day every day. The bigger the starter the bigger the amp draw.
Old 10-19-2009, 01:04 PM
You beat me to it Barefoot, I know a few guys running 1.4's, they do have 300 amp batteries, those compression releases are a dream.
Old 10-19-2009, 01:15 PM
Thing is, motors got to be dialed in. An improperly tuned engine will kill a starting system real quick especially with these big inch motors. Compression release only works for one revolution and then they pop back out with the compression stroke. Mine starts (fires) in less then a revolution every time........less I forget to turn the gas on
Old 10-19-2009, 02:22 PM
My buddy was having trouble starting his 127, we put a 1.75 ultima starter {mainly because it had the button on it, but a 1.4 would have been better except they dont come with the button}, then I installed a new thick ground wire, a new positive wire, and a new ultima agm battery {I think they are 330cca}, bike starts like a dream...
When I installed the open primary on my titan {112inch s&s no comp releases}, burnt out a starter because I forgot to grease the jackshaft cover.... are you sure its not something silly like that wrong????
Old 10-19-2009, 02:34 PM
MAKO6's Avatar
1.4 Kw starter with a 300 cca battery and CR's will spin that sucker up with no effort at all. Been using a Spyke 1.4 Kw "stealth" on my 124 (w/CR's) for a couple of years now and the set-up will even crank it up on cold assed German JANUARY mornings with a used 330 cca battery.
Install quality battery cables, ground DIRECT to one of the starter bolts. get a capable (over 300 cca) battery, check jackshaft alignment, charging system, and go......
Old 10-19-2009, 02:41 PM
clspht's Avatar
Yup...1.4 and a 300+ battery with a correctly timed and carb adjusted motor and your good to go...
Old 10-19-2009, 07:54 PM
CENJIM's Avatar
good advice there.
minimum of 4 gauge cables from battery positive to starter positive lug and from battery negative to a mounting bolt on the starter.
Also, with a new motor it can help to also use some jumpers from a car or truck battery (vehicle not running) during the initial starts needed to dial in the timing and carb. The bike battery must be fully charged. Much more drag with a new motor that pulls more current from the battery. Lessens as the motor breaks in.
The bigger the starter, the bigger the battery has to be. Remember, starters don't create energy, they consume it. The bigger the starter the more they consume/demand.
Old 10-19-2009, 07:57 PM
winston chopper's Avatar
Bike Year, Make, Engine: 2005 CFL 127" elbruto w/ D carb, 6 speed
Got a 250 cca odyssy gel and a 1.75 and it starts my 127" easy. Ground to the frame, and the starter bolt. I had a 275 cca HD battery that was alittle too big for the tray and it spun that motor like crazy!
Dont piss your pants to see if your fly is open
Old 10-20-2009, 02:23 AM
DB DB is offline
We removed a 1.4 that was the original starter because it was not working properly on our 127 build. Installed the 1.7 and worked effortlessly! If you speak to the techs at Rivera Primo, they recommend the 1.7 for large displacement motors (127") . Rivera Primo has been racing drag bikes for decades! The info I got from the pros is that the 1.4 will turn the motor, but will not have the longevity of the 1.7 kw. Actually a 1.6 or 1.7 is recomended for use with a 300 CCA Battery, not a 1.4!!! The 1.6 and 1.7 kw starters are matched with the 300 CCA batteries for a reason, but I'm not an expert on starters and batteries (Magnetos YES). If anyone cares to contact River Primo for more specific information from thier Tech guys, they are a wealth of experience and information!
The Monster Torque Starters made in the USA and Canada are one of the top notch starters available!
BAREFOOTCHOPPA, be careful when you accuse people of being wrong, it can sting!!! If you want to get me on something, you can bash me for saying 1.7 originally instead of 1.6, which I intended to do, just typed an error. But why kick a guy for an honest typo error!!???
Old 10-20-2009, 06:44 PM
Okay, I appologise for that, I had a problem with the "minimal" statement but I stick by the 1.4 being fine if all else is up to par.
Old 10-20-2009, 06:48 PM
A 1.4 will spin a 10.2:1 compression engine just fine!!!
