Whats this Thing Worth??????
Last Post: vsa266
Posted On: 12-05-2019
Eyes
Posted On: 12-04-2019
FXR / FLT Rigid builds?
Posted On: 12-02-2019
Old 08-01-2009, 08:51 PM
Stynie's Avatar
Anyone use a Santee 200 rigid frame???
I'm going to be using a Santee 180-200 tire rigid frame. Has no stretch, and 33* rake. It has no tranny plate, so I need to know if an offset plate is needed. And if so, how much. My frame is same as pic below:
Old 08-02-2009, 12:46 AM
I did a build with that frame.. I used a no offset plate and did the offset all with a PBI offset sprocket. I can look at what size if ya need me too... I think I had to use a 3/8 spacer on the rear sprocket too..
Old 08-02-2009, 08:43 AM
apehangeralfy's Avatar
I'm running the a similar frame with a 1" motor spacer. I am pretty sure that the tranny offset is the same....
Old 08-02-2009, 09:44 AM
Stynie's Avatar
Uh oh! I was told no spacer for the engine. I have a .810 tranny sprocket and was hoping to get away with just that.
Old 08-02-2009, 10:02 AM
MechWerks's Avatar
The magic numbers go something like this:
Stock tire is around 5" with the sprocket centerline 3-9/16" left of the tire centerline (that is chain/belt centerline...middle of sprockets/pulleys).
A 200 tire is typically mounted on a 5.5" wide wheel which often have a .900" offset already built into the sprocket mount. A 200 is around 7" wide.
Basically the chain center is at least .900" left just from the wheel...plus any sprocket offset or spacer needed to clear the tire (tires vary...so be sure a mounted tire/wheel that will be used is available). Once you know the chain center you can decide how a trans offset sprocket, trans offset plate and motor offset may be required. www.chopperhandbook.com has driveline dimensions if you need to find the frame centerline based off the engine mount holes (those should be stock on a 200 frame).
Since there are several ways to acheive offset on a driveline, it is always best to start at the rear wheel, get close then work back from standard offset parts at the engine, transmission and final shim and axle spacers.
MechWerks
Old 08-02-2009, 10:05 AM
MechWerks's Avatar
Stock chain clearance on the 5" tire is quite a bit so there is some room bring the chain closer to the tire on wider modifications. Aim for no less than 3/16" side clearance between tire or frame members. Vertical chain clearance needs to be considerable and varies on application with no magic number other that "no contact at any time".
MechWerks
Old 08-02-2009, 04:24 PM
Andrew C's Avatar
Bike Year, Make, Engine: Rigid in the works
It's a good frame with basic dimensions, should need little to no offset for anything. Don't think they are being manafactured anymore but can be found. I wouldn't hesitate to use one. --Drew
Old 08-02-2009, 07:37 PM
PanJunky's Avatar
Bike Year, Make, Engine: Custom 1988 Heritage Softail
I have a 200 Gooseneck from them. Tried to install the tranny with an offset plate only to find out that the offset I needed was pretty much built into the frame. Ended up using a regular five speed mounting plate.
Old 08-03-2009, 12:03 PM
I have a Sante frame on my rigid.. try to avoid the offset.. unless your engine is perfectly balanced it will cause your rear tire to wear unevenly. Better to go with an offset sprocket as it will make minimal difference. And beleive me.. those 200 tires aint cheap. (Been through 4 of em in 2 years)
Free men are never equal. Equal men are never free.
Old 08-03-2009, 06:27 PM
Stynie's Avatar
I just found somewhere in an online catalog where it said this.
Old 08-03-2009, 09:29 PM
Razorback's Avatar
Stynie, What is the inside deminsion axle block to axle block on that frame?
