My trike build is under way
Looking for Talon lowers
Last Post: goaty cfl
Posted On: 08-18-2017
Clutch adjustment on BDL
Posted On: 08-17-2017
Wiring a new chopper
Posted On: 08-16-2017
Old 03-09-2008, 08:57 PM
Merlin Hawaii's Avatar
DON'T WORRY - BE HAPPY
Originally Posted by Tank Lewis
t
The starter i have barely can push the ring gear around if not lined up properly. Maybe I just got a bad starter, one that was laying around the shop or one they tried in another bike and passed on to me.
Your 310 CCA battery should spin that 1.4KW starter EASILY!!
Do you still have your old starter that you just took off?
You can bench test it (or take it to a shop and have it bench tested) to see if it's still good
Or you can take off the one that you just put on and test it too
Either way you have plenty of battery for your starter(s)
Of course, this all assumes that your wiring and connections are good too
Old 03-09-2008, 09:06 PM
just put a 310cca battery in, I know that is pushing it for a 2.4kw.
I would strongly suggest that you NOT put in a 2.4KW starter:
I don't know that you'll be able to fit a battery with enough CCAs in your battery box
Even if your 310CCA battery will turn it over when all conditions are right, you won't have much of a reserve for when you have less than 100% charge.
Those huge starters also put a greater strain on all of the wiring and electrical components involved
Simply put, you don't need a starter that big. and it is actually counterproductive to what you want to do
Old 03-10-2008, 10:53 AM
Bike Year, Make, Engine: 2004 Hellbound Steel Wicked 107"
Roger That!
thanx merlin
Old 09-24-2008, 01:19 PM
Scrotum, r u for real? You are funny.... if only everyone knows. But I'll let you have ur fun.. I don't want to pop ur bubbles...
"i mss the fun like 80 hour weeks and the parts were easy to make but it was a high cost hbs only had 6 of 7 production people i did all the motors from 04 to my leaving date a coupla wireing guys 3 of 4 builders i fired them and made any last minitue call the they brough back a person who left to go build bikes for bears that shit in the woods he was part of the burning of rome you might say."
Old 09-24-2008, 06:27 PM
OK, Keepin'ItReal, since we're Keepin'ItReal here
How about an introduction?
Whom R You??
And what's your connection to HBS?
Old 04-19-2009, 02:06 PM
Heavy Metal's Avatar
Bike Year, Make, Engine: 2006, 2 Wheeler, 117 S&S
Send a message via AIM to Heavy Metal Send a message via MSN to Heavy Metal Send a message via Yahoo to Heavy Metal
Mine kept blowing starters, batteries and brakes ended up in a junk pile cause could not get brakes fixed and had to move so place I bought it from in daytona could not fix the brakes in time and ended up under a truck.
..!.. LOUD PIPES SAVE LIVES --- CELL PHONE IN CARS TAKE LIVES ..!..
Old 05-20-2009, 03:15 PM
hi i have 05 tormentor any manuals aviable repair ? whats the best way to rear brake pads thanks eddy
Old 05-20-2009, 03:34 PM
Your best manual is gonna be a HD '99 Softail Service Manual
You could also get an S&S Super Sidewinder PLUS Service Manual
Your brake calipers are PM 4 piston "Classic" clones
So any pads for those will fit
Welcome to CC
"Hula Baby"
Old 05-24-2009, 10:05 AM
hi guys anyone interested in an 05 hbs tormentor less then 300 miles mint mint mint thank you eddy
Old 03-04-2011, 04:51 AM
Bike Year, Make, Engine: 2005 Hell Bound Steel
Merlin/fasthd
You all know exactly what brake pads I need for a 2005 HBS Hellion? I heard from a shop in Cali that they are PM 4PST but their seem to be a couple different shapes with that reference. I don't want to end up like "Heavy Metal" as Daytona Bike Week starts this weekend and I just picked this bad boy chopper up las Monday. It has like mill of pad left front and back. I'm willing to try and change them out myself but the back looks like I have to take the back tire off to get to them. Any words of wisdom for me and my new ride would be GREATLY appreciated.
Old 03-04-2011, 05:04 AM
fasthd's Avatar
R.I.P. "MO" WE MISS YOU
Bike Year, Make, Engine: shovel's for ever
first of all take your time the rear wheel don't jut fall right out. i don't have computer access at work right now so i'm sending you my number
Old 09-06-2012, 01:30 PM
Scrotum! Thank you for all the help you gave me last year! Hope all is well with you. Well I replaced my brake pads and left the rear alone. After a major ordeal with the motor oil and a bike shop (too much oil but they started taking the motor apart!) all has run pretty solid. Just recently my starter (?) went out on me and I need to buy a new one. Would this one work? POWER HOUSE PLUS ECONOMY STARTER MOTORS FOR BIG TWIN When I disassembled the rear spindle I found one of the brackets that hold two of the four brushes has come loose. I had a friend spot weld it but then found one of the copper threads around one of the plates of the outside case was broken so I am need of a new one. I am guessing I need to buy the whole assembly? On the inside of the cap I see a APEKS #45-8202 but goggling has produced nothing to match. Bike week is in 6 weeks!!! I sure do like the price of this one I found!
Old 06-08-2017, 08:40 PM
i need a wiring schematic for a 04 hellbound steele chopper
Old 07-23-2017, 03:57 PM
electrical problem
Hi guys I have a Hellbound cycle in my shop and the indicator controle box seams to be not working can someone help me to get one.
Old 07-25-2017, 12:25 AM
Hey guys, I run into one of HBS's builders once in a while. The last time I saw him he was working at a local shop. I'm going down there later this week, if he's still there I'll let you know. He might be able to help both of you.
You might contact Spitfire motorcycles in So Cal, ask for Paul.
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
