starter problem
Last Post: rem hamilton
Swing Arm bushings question
Project Blast!
inner tube for 2000 road king
Posted On: 11-08-2019
Old 07-22-2005, 05:28 PM
geg's Avatar
geg geg is offline
Bike Year, Make, Engine: '00 Titan 96" S&S
Determining S&S Engine Size
When buying a used bike, is there any way to determine the engine size? If the guys states it is a S&S 113, how can I be sure? Is there a visual difference between a 96 and 113?
Old 07-22-2005, 05:34 PM
gypsy chopper's Avatar
113 is much more "fat" looking
Old 07-22-2005, 09:29 PM
Chopper Cop's Avatar
Bike Year, Make, Engine: Sucker Punch Sally 113" 6 spd
Gypsy, based on your usual in-depth and highly knowlegable responses, "more fat looking" is not exactly what I expected to read when I clicked on this thread!
BTW, its a damn good question, and one that has occured to me before as well.
Don't be sexist. Bitches hate that.
Old 07-22-2005, 09:43 PM
well i can spot the 3 different series they have made, i cant tell the individual sizes
but the 93,96, 103 all have cylinders that look sort of like stock...you can see the cylinder stud passages from the outside...and the cylinders actually look stright down the fins, or almost sucked in(sidewinders)
the next series(supersidewinders)..look different at the base of the cylinders(around the bottom fins) and the cylinders fins look pregnant from the side...thats what i meant by fatter 100, 107, 113
the supersidewinder plus series has twin cam heads, and a different fin around the spark plug
plus the twin cam style bottom cylinder base area
so if you drop the instantly recognizable twin cam type SSW+
thats leaves two types, SW, and SSW and one is "FAT"
its all very scientific
Old 07-22-2005, 09:48 PM
Now THAT'S the kind of answer we've come to expect from ya Gypsy!!
So, you're saying the SSW+ 111" in my '04 Texas Chopper has twin cam heads? I never knew that.
Old 07-22-2005, 09:49 PM
BFC's Avatar
BFC BFC is offline
Bike Year, Make, Engine: 05 CFL
commonly refered too as a SWAG......
Scientific Will Ass Guess....... but then again my uncle that thought me how to wrench can tell shim thickess by rubbing 'em between his fingers!
I wouldn't bet with Gypsy on it. You could bet with me though
.....Honey does this engine look fat?
Fuck you is usually the right answer.
Old 07-22-2005, 09:56 PM
yes chopper cop...heads and cylinders are twin cam on all SSW+ engines, also the flywheels are now set up for the crank position sensor
also has piston cooling jets from the twin cam
theres other thing like the machining behind the pushrod tubes, ssw+ actually have the s&s logo at the bottom of the cylinder
i can tell a few shim sizes, but its more of a bet...i use a micrometer to see who's gotta by the beer
Old 07-22-2005, 10:07 PM
Fascinating.
Old 07-22-2005, 10:25 PM
geg's Avatar
geg geg is offline
Thanks Gypsy, I appreciate the info. . . So there is no visual difference between a 93,96, & 103?
Old 07-22-2005, 10:35 PM
actually no
unless you measure the cylinder height you are guessing, and that is not logical
Old 07-22-2005, 11:21 PM
fataz's Avatar
Bike Year, Make, Engine: Rideless again!
Send a message via Yahoo to fataz
Is there a book(outside a shop manual) that breaks down an engine to its core parts. Maybe "The dummies guide to motorcycle engines" or sumthin?
NOW STICK THAT IN YOUR PIPE AND SMOKE IT !!!
Back to the Fun!
Old 07-23-2005, 07:00 AM
Frenchbiker's Avatar
Bike Year, Make, Engine: 2004 TX Chopper, S&S 111 ci
Hmmm, that's strange, Chopper Cop, my 2004 TX Chopper's 111ci engine is a Super Sidewinder but NOT "+". The S&S logos are on top of the cylinders on the left side, when I look at the engine from the front of the bike. On the right side of the cylinder, behind the plugs you can read "SuperStock" in raised letters.
I believe my SSW 111ci is an EVO, not a Twin Cam.
Frenchie
"Sex is like bridge. If you have a lousy partner, you better have a good hand"
Old 07-23-2005, 07:06 AM
S&S SUPER SIDEWINDER PLUS SERVICE MANUAL
The Super Sidewinder Plus engine series - 111", 117", and 124" - 4 1/8" bore manual, is the first in a series, it is designed to guide a technician through the complete servicing procedure of an S&S Super Sidewinder Plus engine. With comprehensive instructions, complete specifications, high-quality photography, and tips directly from the S&S service technicians. Buy your copy today
this is the engine i speak of, this is from their site...and no the motors arent twin cams they are evos, with twin cam heads and cyclinders
maybe big dog has a "special sauce" motor they get from s&s i dont know...but:
it would have to have 2 cams to be called a twin cam i believe
Old 07-23-2005, 09:36 PM
[b]maybe big dog has a "special sauce" motor they get from s&s i dont know...but:
American Ironhorse actually (yeah I know, same thing) but I know its not a twin cam. Frenchy, I'm pretty sure your '04 111" is the "plus" motor. I believe it says it on the left side on the cases. Not sure, I'd have to check it and bike's not here now.
Old 07-24-2005, 08:06 AM
you are right ...unless the wools been pulled over my eyes
i think frenchy is making a mistake based on his bottom end, and assuming twin cam heads means twin cams
