administrator contact
Last Post: saulcid
Posted On: 02-20-2019
Last Post: saulcid
Posted On: 02-19-2019
Last Post: hansheathen
Selling the Shovel
Last Post: madmastiff
Posted On: 02-18-2019
WCC maltese cross air cleaner
Posted On: 02-17-2019
Old 05-29-2005, 08:29 PM
Bike Year, Make, Engine: 2003, Big Dog Chopper
03 Big Dog Chopper won't start
I'm having my first real mechanical problem with my 03 Big Dog Chopper. Parked it last weekend after a good ride and went to start it today and just hear a clicking sound from under the seat. I take the seat off to investigate. I never really have checked out all the electrical stuff under there so I start looking around thinking maybe a bad connection somewhere. I identify the EHC (electronic harness control?) and another 2" X 3" aluminum electronic item that is mounted on the rear fender. It has a big red wire and a smaller black wire and a red light that blinks a few times after the key is turn on. I check all connections and keep hitting the starter button occasionally. The starter finally starts kicking in a few times. I keep messing with the connections and now the starter kicks in every time but the bike won't fire up. I now notice the red light on the 2" X 3" doesn't ever blink. I check the plugs and they're not getting fire. My local dealer went out of business and there isn't another dealer in the state. Can anyone help me out here. Thanks in advance.
Old 05-30-2005, 05:55 AM
brust60's Avatar
Bike Year, Make, Engine: 2004 BOURGET Python Chopper
sounds like a starter problem - pretty common with big dog.
first make sure that the battery is fully loaded.
if it doesn't turn over with the battery full, get a piece of wood, put it on the selenoid cover of the starter (the one with the three bolts) and give it some nice taps with a hammer. this should shake the stuck selenoid loose.
if this helps, you need a new starter.
good luck!
Back on two wheels
Old 05-30-2005, 06:15 AM
Thanks but it cranks great.
Thanks but it cranks great. The battery is fine and the starter cranks great. I'm not getting fire to the spark plug. Anyone?
Old 05-30-2005, 10:49 AM
CLASH's Avatar
Bike Year, Make, Engine: 97 883
how are your coils?
Old 05-30-2005, 11:20 AM
suicide55's Avatar
Bike Year, Make, Engine: BUILT NOT BOUGHT
Try unplugging your EHC for a few seconds then plug it back in to reset it and see if this works.
IF YOU'RE NOT LIVING ON THE EDGE YOU'RE TAKING UP TOO MUCH SPACE!!
Old 05-30-2005, 11:22 AM
brust60's Avatar
how do you know, steve??
Back on two wheels
Old 05-30-2005, 11:27 AM
suicide55's Avatar
Does Mikeys Bulldog ring a bell?? I also sent you an e-mail .Let me know if you can do it. Thanks!
Old 09-18-2018, 08:57 PM
2003 Big Dog start issues
Have an 03 chopper click no start. If run wire to selonoid from battery will start. Wondering what the small aluminum box with relay on and green lights on it. Not getting power to that selonoid wire through it
