help with ultima RSD6
Fender grommets
Last Post: muddychops
Posted On: 10-13-2021
Fender grommets
Posted On: 10-08-2021
Old 08-09-2020, 11:04 AM
R1_4Life's Avatar
Bike Year, Make, Engine: ?
Ok, after walking away and coming back to it, the rear seal bolts both were pretty lose and I was able to get the rear intake manifold flange off. From there the intake manifold just popped out. Off to Lowe's for some massive Vise Grips and a Chisel 😜
Looking for advice from the Old Pros...-screenshot_20200809-135722_gallery.jpg
Old 08-09-2020, 11:37 AM
Yep , I,m not sure what I see on the cylinders or manifold, but bowl definitely cracked.
If you hit the air cleaner, the impact goes all the way to the cylinders, but the only weak link brakes.
If you can find a used but good bowl, try that. If not. Perhaps the whole carb body? If not the carb. Ultima R carb is a great clone of s&s. Make sure It,s correct size.
Keep posted
Old 08-09-2020, 11:44 AM
You in luck, bowl is 80 bucks.
https://www.ebay.com/itm/S-S-CYCLE-N...UAAOSw9Dle6rw2plus do yourself a favor, buy this tool, 15 bucks,
https://www.ebay.com/itm/Intake-Mani...IAAOSwu4BVwfa5
Old 08-09-2020, 01:10 PM
R1_4Life's Avatar
Awesome, ordering now. Thanks
Oh yeah, the intake manifold is cracked at the flange
Looking for advice from the Old Pros...-screenshot_20200809-160624_gallery.jpg
Old 08-09-2020, 02:48 PM
You have G carb, correct?
Here,s manifold for about 30 bucks or less
https://www.ebay.com/sch/i.html?_fro...ma+r2+manifold
Old 08-17-2020, 02:25 PM
R1_4Life's Avatar
... Mail man brought some goodies today! To bad its the wrong Manifold 😠
It's slightly larger than the one I have
Looking for advice from the Old Pros...-screenshot_20200817-172311_gallery.jpg   Looking for advice from the Old Pros...-screenshot_20200817-172306_gallery.jpg
Old 08-17-2020, 02:30 PM
R1_4Life's Avatar
Carb bowl also made it in today... Then I remember that I never ordered a new seal 🤬.. Way to go dumba$$ 🤦🏽*♂️
Looking for advice from the Old Pros...-screenshot_20200817-172708_gallery.jpg
Old 08-17-2020, 02:48 PM
G's have a gasket should be ok , and dont forget the little blue o ring on top of the accelerater pump tower.
Old 08-18-2020, 05:10 AM
axeychrome's Avatar
learned that lesson early in life!
Axe - record for fastest motorcycle ride across America
"No Limits - No Regrets" movie
http://www.ychrome.com/movie
Old 09-08-2020, 06:41 PM
I always put headlamps on a relay. My chopper has the low beam wired to the normally closed side, the high beam to the normally open.
Old 10-03-2020, 07:25 PM
R1_4Life's Avatar
Well she's back up and running. She runs strong as before, with no major issues but there is a few things that need to be tweaked...
- I need a gas tank! I can't stand the dent 🤦🏽*♂️
- I want to replace the rear tire but the riding season is fastly come to an end so I'll just wait till the winter rebuild but I was curious. Should I go 260? I've read that a 260 gives better handling over a 250 due to the difference in profile. Also I'm curious that I might not have the clearance between the rear fender if I swapped up.
- My new headlight, low beam stopped working the other day. It was working when I parked the bike the previous night, but the next night when I first went to head out, it was out. The high beam still works though.
- The carb has been the biggest thing that has changed. I took it apart, cleaned it and replaced the o-rings and diaphragm. It was pretty dirty. Now that it's back up and running, the carb runs totally different. It spits ever so often at cruising and it seems not to be running as smoothly in the lower rpms. To me, it seems to be running a lot richer.
Looking for advice from the Old Pros...-screenshot_20201003-141629_gallery.jpg
Old 10-05-2020, 10:06 AM
axeychrome's Avatar
don't understand why a 260 would handle better than a 250? figure if motogp is sticking to 190, there's probably a reason for it, and most of us are way over that.
i guess you're saying the radius of a 260 tire is better than a 250? you'd be changing brands too? the brand might be the difference, but again, i'm not sure of the basis for this.
carb is spitting? so irritating. any chance it's a leak somewhere? manifold or anything? cleaning it shouldn't make it richer assuming same jets. guess go back through the tuning process. maybe was rich before to account for it being dirty?
Old 10-22-2020, 09:55 AM
R1_4Life's Avatar
axeychrome,
In doing some research about 250 tires, I read that a lot of guys that normally run 250 rear, switched to a 260 because of the difference in profile. Apparently the 260s profile is curved more and not as flat as a 250s profile and is said to corner better.
Old 10-23-2020, 05:39 PM
axeychrome's Avatar
axeychrome,
that is interesting, had never heard that. i don't think i even remember a 260 when i was building. there were 230,240,250, and same size of a metzler was different than an avon, etc.
i think the 300 rr tire on my current chopper is less of a burden on handling than the 47 deg rake up front haha.
sounds like you did your research and are getting what you want though!
