Last Post: logan
Rear Master Cylinder
Posted On: 08-05-2020
Show us your bike!!
Last Post: necozzi
My Big Dog chopper
Last Post: necozzi
Posted On: 08-04-2020
Old 09-28-2019, 06:47 AM
My Evo & 5 speed in FLH 4 speed frame
Basically completed my transplantation of rigid evo bobber with 5 speed onto Kraft tech FLH frame designed for Evo , but with 4 speed tran
Not without challenges, it it,s fun in itself .
Some minor details left to do, but it,s rideable .
Man , the suspension is great.
Now work on rear fender, either close to tire on Swingarm, or a solid on the frame, short, sharp , raised up, like in sports bikes.
Old 09-28-2019, 03:37 PM
Nice ride. I think your right on the rear fender, mount it to the swing arm if you can.
Old 09-29-2019, 03:40 PM
Oil out of foot clutch cable. Little, but annoying
Everything is ok with the bike. One thing is annoying and embarrassing
is transmission fluid drips a bit out of foot clutch cable, right where the stupid adjuster is located . If it was higher , it might not com out normally.?
I have heard oil coming on regular Harley cables , up, I assume with pressure.
I have another shorter cable, on my chopper , the adjustment is right by the pedal, definitely higher- not leaking.
Wonder if overfill. Or vent issue , or , even if they are not a prob
Em, then the design of the cable and gravity inevitably make it happen?
Any other possibilities?
I assume the cable entry is below the transmission oil level. O- ring keeps oil from outside, but how about inside the cable jacket- right to the point of adjuster?
Any help or even sharing experiences would be appreciated.
Old 09-29-2019, 04:49 PM
Thanks. I will look into both options.
Old 09-29-2019, 08:30 PM
What clutch is that on the bike with the open chain? Can't see it, but it looks like a belt pulley
that's not used..what am I looking at? or is that the auto clutch?
Old 09-30-2019, 06:49 AM
It's a house salad of parts- 1993 harley basket/clutch on which instead of original double sprocket i machined a bolted on single sprocket 50 T.
the motor sprocket is actually a 25 no offset transmission sprocket, opened up to bolt on to Ultima front pulley collar.
the backing plate/bearing /starting support is half of karata primary.
and the auto clutch is York clutch designed for BDL, but i was able to install it on the harley hub. the adjustment of rpm engagement is achieved by placing different thickness spacers under 6 holding bolts: the thinner- the earlier engagement.
Old 10-01-2019, 10:18 AM
If I was still a hippie, and I still am, and I could travel back from the 60's with my bell bottoms,
I would not want to ride your motorcycle..
Old 10-04-2019, 12:31 PM
damn beautiful bike man. good work.
Old 10-04-2019, 06:33 PM
Thanks fellas, tomorrow will post a picture with rear fender. Decided with the fixed to the frame, sporty ducktail. Always can change to Swingarm fixed.
Old 10-05-2019, 05:32 AM
Here comes the fender
Here,s my new fender on the FLH. Used sheet of 1/8 aluminum , 3000 series, pretty malleable.
Did it in a manner similar to my chopper.
It started like this
And finished like this
Old 10-05-2019, 03:39 PM
That really added a nice touch..
Old 10-05-2019, 06:01 PM
TY. Also relocated my tail lights to much better location on the new fender. And cleaned up the Swingarm from the ugly taillight brackets.
Old 10-07-2019, 11:35 AM
you damn talented SOB!!
Beautiful work man. lol
Glad you went frame mounted over swing arm mounted (personally) hate the way it looks.
Damn nice man.
Old 10-07-2019, 04:02 PM
Damn nice man.
Thanks. When I was building my scoot I had in mind perhaps the most aggressive silhouette of FLH bobber I have ever seen. The guy doesn,t have a fender and I believe his total rake is closer to 40 degree.
. I loved it.
Old 10-08-2019, 06:16 AM
You need to have at least something back there, a partially wet back is better than completely saturated, not to mention the looks..
