Posted On: 08-11-2020
Last Post: logan
2004 Bourget Retro
Posted On: 08-10-2020
Posted On: 08-09-2020
New Forum Member
Old 07-30-2019, 06:13 PM
Maustarman's Avatar
Bike Year, Make, Engine: Ultima 127
Oil Lines
Alright!
I've been working like crazy in my project and now I'm at the point where is time to think about the oil lines.
what do people recommend in terms of line size?
The other issue I'm having is to figure out what fittings I'll need. I have no idea what size I need to get those. When I got the project everything was new in plastic tubs and somethings like the oil tank ni idea of who made it or where was it purchased.
Are those normally one size no matter who made it? is it a Pipe thread?
any guidance will be appreciated
Chopper project
with Ultima 127ci and ultima transmission
Old 07-30-2019, 07:02 PM
What fittings do you have on the oil tank? that is what you need to go by..does it have screw on fittings? Measure the hole....or if it has fittings you can compress aluminum foil around the fitting
(make a nut) then unscrew it and take it to a tractor place and have a hose made..I have done that..many times..or if you can determine the fitting size, JEGS has lots of custom hoses.......no it will be fine threaded..
Old 07-31-2019, 04:51 AM
I use 3/8 black OIL lines from regular auto stores with stainless screw clamps. Simple and effective. Didn't even bother with cosmetic end cups that one can order in bulk: They also utilize the screw type clamp inside.
I don't have any leaks.
In the past i tried stainless braided lines- too much drama for my taste.
Old 07-31-2019, 02:38 PM
+1 on Steinbvg - KISS
Old 08-07-2019, 09:56 AM
Poop's Avatar
Slow=Smooth, Smooth=Fast
+1 on calling steinbvg stupid.
but seriously, black is the way to go. scuff off the white lettering with a scotchbrite.
Old 08-08-2019, 03:02 PM
+2 calling steinbvgs stupid...and cheap.
Love skotchbrite on aluminum. Better look than polish to me.
Never thought of removing oil line lettering. Sounds like a good idea.
Old 08-10-2019, 08:53 PM
Maustarman's Avatar
Thanks everyone!
Very helpful suggestions ... now waiting on parts and get to work !
Old 08-11-2019, 08:25 PM
Did you get your off set sprocket and get it to line up?
Old 08-14-2019, 09:06 PM
Maustarman's Avatar
Ok got the oil ports identified!
Had to resource to a dentist inspection mirror and managed to figure out what was what !
Right side =feeder
Center = Return
Left = Breather
Old 08-14-2019, 09:08 PM
Maustarman's Avatar
Yes, that was a royal pain in the rear !
The final offset is 1.875 inches
