Substituting an 16" rear wheel for a 18" question
Last Post: erlobulldog
Last Post: chopperfugger
Posted On: 04-05-2020
Pushrod u still on here?
Last Post: fifty
Posted On: 04-04-2020
Posted On: 04-03-2020
Old 06-07-2019, 10:10 AM
2007 Big Bear Screamin Demon Parts List
Just purchased this bike a month ago. This is my first custom. It needs some TLC. Right now I am dealing with a starter/solenoid issue. I will likely have to rebuild or replace the starter or hopefully just the solenoid. I also only have one key. I've been to several hardware and bike shops locally and no luck for a key.
I've contacted Big Bear directly and their response was "Sorry we no longer have any information for these bikes." I also do not have a local authorized Big Bear repair shop.
I have the VIN #, the motor numbers, etc. Anyone have any idea how I can get a parts list or some source of information on the parts?
Any advice is greatly appreciated.
Old 06-07-2019, 05:39 PM
I built one of their bikes in 2006. Do you know if they built it ? The new BBC doesn't want to deal with their old bikes because of the frame issues. If I recall, they used Spyke starters, its just an HD evo softail starter.
FWIW, I don't recall if the SD frames were on the recall list, I dont think so.
Does it have an S&S engine and Baker trans?
This thread might explain the reason why the "new" BBC doesn't want to help with your bike. It might be the biggest Dick move to ever hit the business...
BBC frame weld problems
Old 06-10-2019, 03:42 AM
From what I know it was built by them and it does have the S&S and the Baker Tranny. And I think you are right about the frame. I have not seen the Demon on the recall either.
I appreciate all the information. I know it's a "custom" but was still hoping for a parts list. From the research I've done looks like I am going to have to document the parts myself.
One last question if you or anyone can help. Since I will likely be replacing the starter on recommendations on an upgrade? Thanks again.
Old 06-10-2019, 01:39 PM
Technically it's not a custom, it's a factory bike, the factory just went BK . If it still has the factory starter than there really isn't an upgrade. The Spyke startes are about as good as it gets.
I'd just remove the starter and take it to your local Indy shop and have them order you a new one. It's just two bolts, the cable bolt and a plug. Those starters are about $360.00. You also might be able to have it rebuilt. You can find the Ultima starters for about $160.00 on Ebay and Amazon. I've read good things about them but they're not an upgrade.
Good luck
Old 06-10-2019, 02:27 PM
I sell the All Balls I seem to have the best luck with those. I have used them all
Old 06-10-2019, 03:38 PM
OP, if you want to save some time and money, contact pushrod241 and he can send you the right starter. As mention, the All Balls starters are top of the line....
If you post up some pictures of parts you want to ID we may be able to help you. Lots of common parts on these bikes used by HD, and other factory built bikes like Big Dog and such. I have a custom bike that uses a lot of the same parts that my BBC does, did....
Call Scooters Performance at 407-330-2056
Old 06-18-2019, 08:21 AM
waxlrose's Avatar
Bike Year, Make, Engine: BBC, FXDL, XL
I also own a Screamin Demon. It's not my daily ride, but I purchased it back in 2012 and never had any issues until today. S&S motor, Baker tranny, PM brakes etc.
I know the reputation of the Company is very bad, but it'a a good bike and makes lot of fun.
Do you have a pic of the bike?
I don't wanna change the world, I don't want the world to change me
Old 06-18-2019, 08:58 AM
Good to hear. I lover my BBC, I dont know why I let it go.
At the end it was robb from peter to pay paul. They were taking orders fof bikes right up to the very end, knowing all along those bikes were never going to get built.
Old 06-20-2019, 03:02 PM
Thanks for all the replies. Got the bike out of the shop. The starter got replaced along with the jackshaft and the starter ring gear. I've got a Braille 800CCA battery on the way. I've only got a 200 CCA in there now but with a 1000 CCA jumper on it and no decompression it turns over nicely. Actually as long as it's not on the decompression stroke (and the engine is warm) it actually starts but if it is on the decompression stroke forget it.
My shop also said that if I don't get the right battery they will not warranty the starter. I am thinking it should be good. Worse case I guess I could always keep a spark plug wrench with me if the battery dies and it's on the decompression stroke.
Thanks again for all the replies. I am going to continue to document all the parts for this bike as it is all original. Any questions about BBC Screamin Demons please PM me. Thanks again everyone. I hope to give back after all the help.
Old 06-21-2019, 12:41 PM
800 CCA? Thats more then twice what you need. I just installed a Shoria battery that has 315CCA. Its more then I need.
Old 07-21-2019, 08:37 PM
Yeah I thought it was quite excessive but so far it's been firing without hesitation every time. As an aside my brother found a vid on you tube of a guy with an open primary. He gets on but before he hits the start button he reaches down and spins the primary and gets it off the compression stroke.
I tried it a couple of times and a couple of times it was on the compression stroke and I was able to get it to the bottom of the stroke (I think) and it fired. But of course I had the 800 cca battery already.
Hope that helps someone.
Old 01-02-2020, 08:28 AM
Bike Year, Make, Engine: 07 big bear pro sled, 127ci el bruto
Any of y'all knows anything about 07 bbc pro sled parts? I was told that I can no longer buy the sprotor for this bike. Is that true.
P.s. are these good bikes?
Old 01-02-2020, 03:53 PM
I don't recall the sled being on the recall list, it might be something to look into on the BBC subforum here. I had a O6 DA prostreet that I built from a kit they put together for me. It was a nice bike made with top quality parts. It should of been since it cost me 21k ..
What parts do you need for the sprotor? There were a couple companies that made them for BBC. You should be able to buy rebuild kits for them .
Can you load up a picture of it?
