Last Post: chopperfugger
Last Post: cntrhub
Seen the new Harleys?
Posted On: 03-31-2020
What are these?
Last Post: erlobulldog
Posted On: 03-30-2020
Last Post: CIC2016
Posted On: 03-29-2020
Old 01-17-2019, 08:33 AM
Poop's Avatar
Slow=Smooth, Smooth=Fast
i think like roger on this. at the very least, it's increased heat and accelerated wear. at the worst, get slapped (ripped) by a slung chain, or rear wheel lockup.
either way, i'd want to fix it.
Old 01-18-2019, 06:32 AM
Tx51's Avatar
I checked the tire as ed suggested...the tire is not setting well around wheel, it almost makes the wheel look crooked....I had another set of eyes confirm and the "gaps" (dont know the proper term) between the tire and wheel are different all around, (only on the left side) especially where the chain rubs the tire. Right side is ok. Do I deflate first, then over deflate ? Or just over inflate as is and let settle?
Chesty Puller
Old 01-23-2019, 06:21 AM
EdCase's Avatar
I'd deflate it then lube the tyre edge's with soapy water then pump it back up again to seat the tyre on the rim.
You might get a loud pop/bang as the tyre slips into place.
After the tyre has seated, deflate it to your desired pressure.
Sometimes you dont need to over inflate the tyre, with a little soapy water to lube the tyre against the metal wheel rim they can just slip into place.
Tea is for mugs
Old 06-17-2019, 06:04 PM
Tx51's Avatar
I'm about to give up soon, I cant find the culprit in this. I did as all suggested and nothing. I even notice the bike forcefully taking off as if the chain was too tight or something (ckd the chain it's good on slack). My only (last )last resort is replacing that swing arm. Let me explain......
I will try to keep short....tried to sell / trade, guy took for a ride, dropped n fucked my bike up (that's why new paint job n wheels n other things and I kept it). The swing arm is scrapped on back end of the axle cover. My thinking is that swing arm is bent. Ideas anyone?
Chesty Puller
Old 07-16-2019, 07:01 PM
Tx51's Avatar
Could bad seated bearings cause this? I think one side of mine is off, just doesnt feel right...almost uneven
Chesty Puller
Old 07-21-2019, 02:05 PM
Tx51, have you tried other forums for help.
Chop cult has a lot of good people..
Main Forum
