Last Post: chopperfugger
Last Post: juanba
Posted On: 05-27-2020
Rear wheel spacer
Posted On: 05-26-2020
Posted On: 05-25-2020
Pushrod adjust.
Old 08-15-2018, 08:52 PM
Considering this Chopper help needed
This bike is for sale locally and has caught my attention
When I went to look at it, of course it started to downpour so I didn't ride it.
Bike is super clean and looks well put together
It has the following:
100" El Bruto engine
6 speed
American Suspension Dragon Springer front end
Hardcore II Frame
Custom ceramic coated exhaust
3 1/2" open primary with tribal outer bearing support
Powder coated teardrop fat spike rims
Custom oxhide spring seat with adj mini shocks
Custom Maltese cross oil tank
Avon cobra tires
Any thoughts, comments, suggestions, things to looks for etc...good or bad is def appreciated
Thanks in advance
Considering this Chopper help needed-img_8448.jpg   Considering this Chopper help needed-img_8449.jpg
Old 08-16-2018, 08:10 AM
6 speed
Hardcore II Frame
Avon cobra tires
Thanks in advance
Not a bad looking bike. As long as t's solidly built, runs and rides well and you like it.
Try to get the wiring schematics- perhaps the most difficult issue to trouble shoot , when custom wiring is frame hidden and done by somebody else...
Good luck.
Old 08-16-2018, 09:22 PM
Good luck.
Thanks for the heads up on the wiring...I hadnít thought of that.
I appreciate it!
Old 08-17-2018, 06:12 AM
Neverlost's Avatar
6 speed
Hardcore II Frame
Avon cobra tires
Thanks in advance
I've got a hardcore 11 frame with a 113 ultima and love it. Not sure about the seat setup. The front end looks good..right price it would be a great bike
Old 08-17-2018, 11:54 AM
Looks nicely done, however, check your state laws. It looks like the bike has no turn signals, speedometer, or front fender...could need a horn and maybe a second mirror. If this is your first custom bike check how the bike is titled then call your insurance company to see if they'll insure it.
Old 08-18-2018, 04:43 AM
chuck1073's Avatar
You can run into all kinds of stuff when registering a custom. Here in CT all of the above, except for the fender, failed my '72 Ironhead chop. They also wanted a high beam indicator and failed my exhaust, even though they were stock pipes from that year sportster. Inspectors said "too loud". I ended up having to register via a friend in a neighboring state.
'72 Ironhead Digger
'07 AIH Texas Chopper
Old 08-18-2018, 04:59 AM
Thank you sir...I bet your goes good with the 113"
Old 08-18-2018, 05:02 AM
Great points..I considered this when looking it, figuring I would have to add a few things to satisfy the state/ins co.
Thanks for your comments
Old 08-18-2018, 05:04 AM
Good points sir...hadn't thought about high beam,I'll have to check and see if it gas that.
Thanks for your input.
Old 08-19-2018, 07:18 PM
Changing a tire on powder coated rims can be a nightmare..I f you ever have to do it make sure you use the cable ties method, you can find videos on you tube..even a rubber coated tire tool will screw them up with out them..
